After reading the suggestions...scoping out the added info links...I think I might try to hang a new handle. ( You know with that Scout of mine ) That will depend on what's available to me at the local hardware store. I'll let you know how it works out. Thanks again.
hanging the handle is a critical skill set - you will be glad that you did, brother.
just remember what a lot of folks forget - align
the bit to the butt, not
the eye to the butt.
some of the most
twisted up, cupped heads that i have put handles on
markedly outwork beautiful hawks, hatchets, and axes, becaues the
strike point of the bit on the
Fugly Hawks is aligned to the most distal point of the haft
(the butt). - i foudn that out a couple eyars ago when i was stuck with some really twisted up hawk heads that i originall perceived as a disadvantage.
it's not always true, of course, but i thought it was relevant enough to mention.
On a hawk or hatchet
with a flat top, like the
Cold Steel Trail Hawk, that
strike point, that i mention here, is usually the
top 3/4 inches, if even that much of the bit. - ignore where the non-strike area of the bit trails off to on curved bits
(vice straight bits) - which is a lot of times off to one side -
i think that deviation helps splitting as well, similar to the physical principles behind those
twisted diamond wood wedges.
food for thought if nothing else, from a guy who has hafted and swung quite a share.
vec
