Not proper, but an acceptable amount of accidents before my wife takes away my toys.I like how this somehow implies there is a proper amount to stab yourself...
Dude you can get the small set of multiple grit Venev diamond stones for about $100 bucks and also learn freehand at the same time. I was a bit shy to do freehand until I watched some YouTube videos with Michael Christy. Start with his short Bevel Alignment video. Hope that helps.
On Sharpening knives:
This is a new knife
This is a well used knife
As long as your knife falls somewhere between these two, you will retain a perfectly useful knife. There is no need for extensive sharpening skills and equipment in the attempt to replace a perfect factory edge. A few scratches, dings and irregularities are fine, so long as it cuts. It adds character, personalizes the knife and no matter how poor your skills the knife will last you for many years and every time that you sharpen you will have a new opportunity to learn and perfect your technique.
n2s
Lots of good points there and I especially agree with the last one. Short edged instruments are generally poor defensive implements, which is bad news for the good guy. The bad guy already has an intent to hurt and can do a lot of damage with the initial sewing machine attack. The good guy with a Paramilitary 2 needs a fuckton of luck and skill to repel an attacker.Fixed for strength, folder for convenience.
Always have one on you. Murphy is around the corner.
What you carry and why you carry it, is your business alone.
Don’t let others use your knife. Tell them to carry their own.
Understanding a point and/or edge means you are never without one.
A knife is a tool that can be used as an improvised weapon but a knife is NOT a weapon.
Holy schmokes, it evolved into a recurve knife!On Sharpening knives:
This is a new knife
n2s
Another thing that can be added to your first lesson is to never use pull through sharpeners.Most important lesson(s) ?
1) You don't need to wear away a lot of steel to get a sharp edge. So... don't use rough stones.
2) Factory edge is (almost) never perfect. But a good place to start.
3) Sharp is according to your needs. Some like a rough edge, some like it mirror polished.
