David Nowlin
- Jan 17, 2018
I read a post about problems in fusing poly and nylon cords together. When being heated or melted, poly behaves different than nylon. It makes fusing them together difficult, so that steered me into using nylon/nylon cord. I also found that poly seems stiffer and isn’t as cooperative as nylon when it comes to tying the more complicated decorative knots. It’s probably fine for general use, but I like nylon/nylon cord better for lanyard use.I hadn't thought of the differences in cord being due to different materials. I'll have to go through what I have--probably 15 or so hanks--and see if there are any marked labels in what bags I have left. Judging from what you've said, Stumpy, I'm guessing that the softer, more pliable cord I favor is likely nylon/nylon which is much easier to form and holds shape better.
Thanks for the tip on Paracord Galaxy. I just checked them out and saw that all their cord materials were spec'd jacket and inner strands as you mentioned. Their prices look good too. I've had good luck buying from Bored Paracord since switching to them, and, looking at their site just now, see that they mention all their 550 is 100% new nylon. I stopped buying from the Big River Site and their primary vendor as what I received from them was very spotty. I have several hanks I purchased there that I'll never use for lanyards and just kept for utility around the house and carry in the truck for general use.I read a post about problems in fusing poly and nylon cords together. When being heated or melted, poly behaves different than nylon. It makes fusing them together difficult, so that steered me into using nylon/nylon cord. I also found that poly seems stiffer and isn’t as cooperative as nylon when it comes to tying the more complicated decorative knots. It’s probably fine for general use, but I like nylon/nylon cord better for lanyard use.
I have no good local outlets for buying cord, so I ended buying online from Paracord Galaxy. They specify the materials of all their cords (which means a lot to me) and their inventory of available colors and thicknesses is extensive. They enabled me to get into nylon/nylon in different thicknesses and a world of different colors.
Now all I have to do is build some proficiency at tying lanyards. I’m only just starting to obtain a basic grasp of proportion, balance, etc, but this morning’s effort came out fairly well:
When I disassemble my CRK's for cleaning I’ll probably just cut the lanyard off and tie another one on after the knife is reassembled. Cord is cheap, I’m retired and have too much free time to burn and it’ll help me build tying proficiency. Besides, I’ve got eleven 100’ hanks of cord to play with, so that pile will outlive me if I don’t make a point of using it up.Thanks for the tip on Paracord Galaxy. I just checked them out and saw that all their cord materials were spec'd jacket and inner strands as you mentioned. Their prices look good too. I've had good luck buying from Bored Paracord since switching to them, and, looking at their site just now, see that they mention all their 550 is 100% new nylon. I stopped buying from the Big River Site and their primary vendor as what I received from them was very spotty. I have several hanks I purchased there that I'll never use for lanyards and just kept for utility around the house and carry in the truck for general use.
I see you favor the same method I employ for lanyards on CRKs, eschewing the pin and simply going through the vacated hole. Some will say that you have to untie the lanyard to take your knife apart, but I don't mind leaving the slabs joined by the cord if completely disassembling, and of course the preferred method re-lubing a 21 leaves the slabs together and requires just pulling the blade, washers, and pivot bearing out the front anyway. One could always tie the lanyard around just one slab as well, similar to a Shiro F95 with the single-slab lanyard hole.
There's definitely something to be said for tying up a fresh one. If your knives are users, it doesn't take long for a handsome lanyard to turn into a dirty piece of string.When I disassemble my CRK's for cleaning I’ll probably just cut the lanyard off and tie another one on after the knife is reassembled. Cord is cheap, I’m retired and have too much free time to burn and it’ll help me build tying proficiency. Besides, I’ve got eleven 100’ hanks of cord to play with, so that pile will outlive me if I don’t make a point of using it up.
Thanks for the tip on Paracord Galaxy guys!!!Thanks for the tip on Paracord Galaxy. I just checked them out and saw that all their cord materials were spec'd jacket and inner strands as you mentioned. Their prices look good too. I've had good luck buying from Bored Paracord since switching to them, and, looking at their site just now, see that they mention all their 550 is 100% new nylon. I stopped buying from the Big River Site and their primary vendor as what I received from them was very spotty. I have several hanks I purchased there that I'll never use for lanyards and just kept for utility around the house and carry in the truck for general use.
Yeah, I'm really pleased to have mine. I bought my son one a couple years back and have wanted one for myself since that model first came out. This one came off the Exchange as brand new as could be for eighty bucks off current retail. I like big knives, don't mind a bit of weight--especially for a work/hard-duty user--and it fits my hand just great. It came with a quite sharp, toothy, BM working edge that'll sharpen up great with its excellent plunge grind/sharpening choil configuration.The beads matches great with the pivot collar. I'm really pleasantly surprised by how much I love and carry the Crooked River.
