- Aug 19, 2000
The Bauschinger Effect
For both single crystal and polycrystalline metals,any change in the stress-strain characteristics that can be ascribed to changes in the microscopic stress distribution within the metal,as distinguished from changes caused by strain hardening.In the narrow sense,the process whereby plastic deformation in one direction causes a reduction in yield strength when when stress is applied in the opposite direction.
ASM METALS REFRENCE BOOK SECOND EDITION
WHEW-what a mouthful. In a nutshell what it means -in broad terms that relate to us- when material is moved enough to permently deform,thats the plastic deformation part,by forging bending etc.you lose ductility.Ductility is the reduction in yield strength mentioned in the last part. Kindof-Its not exactly the same but works for this example. If an edge is too hard it will chip when flexed on the brass rod test. Pretty simple in concept. The trick is to get the edge as hard as possible and then reintoduce ductility by tempering. This is what seperates the good ones from the also rans. Testing by flexing gives immediate feedback to the maker as to where this line is at.
If you don't chip edges at the begining of your experiments you are either not getting the maximum hardness possible or else you are overtempering. The trick is to sneak up on it a little at a time until you are satisfied with the results. After a few trials it is then possible to reproduce the results repeatedly. Different lots of steel will need to have times and temperatures adjusted . This makes it a good idea to work with known material. The learning cure will be much faster and you avoid the variables caused by material, which can leave you schratching you head wondering what went wrong.
Rex
First to answer some questions. Etching the blade will not ruin it for a knife. It is a surface condition only. The steel will be VERY prone to rusting, sometimes in only an hour or two if humditiy is high.
The muratic acid should be mixed 50:50 with water. If the solution is a little weak it will take a little longer to etch.Straight acid does not etch very well. It works better with water Old solution does not give as clean an etch as fresh and does not show structure as well. If you leave the sample in the acid too long it will have a dark burnt appearance.
Pressing and hammering will leave different properties in the steel.
Note that there is a lot of overlap but GENERALLY a press is more powerful and slower than a hammer.A press will move material both longitudinally and transversly{It squashes things}, A hammer moves less material per cycle but the force is more directed. Yhe sharp rapid blow of a hammer will tend to breakup inclusions and refine the grain more than a press will. Different dies can be used to help direct the metal flow. The BAUSCHSINGER EFFECT is really a kind of red-herring . It mainly manifests itself in material that has been cold worked . In oil country tubes its most notable after a tube has been heattreated and then needs run through a straightening process. At this point it is given a quick stress relief in a furnace . A complete heattreat will almost always prevent this phenomenon from occuring.
Rex
