Call me crazy , but . . .
This blank is from ball bearing , normalizing and grain refining was done and LOOK at that scales ! Before normalization, the blank was heavy coated with ink corrector /if that is right name? / I used it for HT same steel and it works but obviously it not work on looooong process ?? I know that there are other protection to coat steel but I have not them and I am not sure that they 100% protect steel from decarburization on surface ...
NOW what if I wrap steel in 0.3mm thin sheet ? Not stainlees steel foil , ordinary one ? I mentioned 0.3mm just because that is what I have around me at moment .It is so easy to work with that soft like butter /Million dollar question is would it survive thermal cycling?? I guess a little thicker sheet like 0.4 or even 0.5 mm would work if 0.3mm is too thin ???
So , am I crazy or is there something here / What do you think ? What I am missing ?
Blank after thermo cyciling , under it is a that 0.3mm thin sheet and small blank ready to be wrapped and thermo cycled
