- Oct 30, 2018
Ladies and gents,
Bit of context - I have a series of old kitchen knives that are far too thick behind the edge, I’d like to have a go at thinning them.
Problem is I have none of the kit you’d typically use I.e no belt sander, wheel or particularly coarse stone (diasharp coarse is as coarse as it gets for me). As this is likely to be an infrequent occurrence I don’t necessarily want to invest heavily.
I was thinking of getting some 120grit SiC paper and giving it a go.
Any thoughts / experience using this method would be welcome, including how to effectively mount this on a flat surface.
I did consider purchasing the washboard system but if I were to go down this route I’d probably settle for an extra coarse stone such as the manticore although I think shipping to the UK would cost more than the stone!
Thanks in advance
EDIT: I should add that achieving an aesthetically pleasing result is not a success criteria!
EDIT2: Maybe I’m barking up the wrong tree here and you’ll just advise me to spend 50quid on the Shapton Pro 120...
Thanks in advance
