I have an Evenheat KF22.5" and I also have a Paragon KM18D. I use the Paragon oven when doing one or two smaller blades and use the Evenheat for batches and bigger blades.
The Paragon is built much more solidly, but biggest difference is the outside of the Evenheat gets much hotter than the Paragon. Unsafely hot, in my opinion, but it works well, otherwise. Both do HT perfectly fine.
I got the Paragon from Ron Frazier's shop after his passing.
I got the Evenheat in a very happy way. Another maker ordered one and when it came, the box had been damaged. The door had been bent crooked by about 1" and the wooden knob was knocked off. The controller unit was pulled loose from the oven body ( four small sheet metal screws). While very severe looking, this was pretty minor damage, actually. All this damage was because the Evenheat ovens have a rather thin wrapped stainless steel shell.
He called the company and they said a replacement would go out that same day. He was to put the damaged unit in the garage, don't pack it up, and have it ready for the delivery driver. The driver came in a few days with the new unit and asked to see the damaged one. He looked at the damage and said, OK, and gave him the new unit. He went to the truck and got an ax and came back to the damaged unit. He explained that the company instructed him to destroy the unit and put it in the trash. He looked at the fellow, grinned, and gave it a light tap on the top to make a tiny dent. "That should do it", he said, got into his truck and left. I screwed the controller back on with four larger screws ( the old ones were too small IMHO, anyway), straightened the door hinges, and screwed the door knob back on. We split the cost of a new unit and each had a half priced oven.
I have considered that the heat from the stainless steel shell is caused by some sort of cracking in the refractory lining, but have never found anyplace that looks damaged.
How hot do the outside of any of you guys Evenheat KF22.5's get? I can't touch the top of mine when doing HT or I would get a bad burn.
