- Mar 26, 2002
For bushcraft, you are pretty much left with three cutting options beyond
your knife: the axe, machete, and saw. The idea of this article will be to
discuss the pros and cons for all of them, including some you may not have
taken into consideration.
Selection- a tool that in the best of circumstances will be used for cutting
wood for a fire you want, instead of one you need. This, along with shelter
building, are the most likely tasks.
Carry- The first thing we need to look at is weight. More weight translates
to more calories burned just to carry. Lets see how they add up. I will use
common examples-
Wetterlings 19 in axe- 1.5 lbs
USGI Ontario 18 inch machete- unable to find weight on line, approx 2 lbs
Gerber Sportsmans Saw- 3.4 oz
Use- Again we focus on cost vs benefit, with calories as the currency.
Lets take a look at the mechanism and physics behind using the different
tools.
Axe- The axe relies on centrifugal force created buy using the human arm
with the axe attached, as a pendulum, to deliver a concentration of force on
a small surface area (sharpened edge) to chop wood. The fuller and more
relaxed the motion of the arm, the more economical the use. Any injury
limiting the arm, or the wearing of restrictive clothing, will greatly decrease
efficiency. Because the entire body is at least somewhat involved with
using the axe, it can burn lots of calories. Because of the cutting surfaces
small area, extreme concentration is needed to place cuts. Any eye injury
will severely limit effectiveness.
Machete- Using the same basic premise as the the axe, the machete
is swung, using the entire arm to concentrate the edge of the blade on
the target. Again, effective use of the machete is compromised by any
injury to the arm, or the wearing of heavy clothes. Because of the larger
cutting surface, a bit less concentration is required. An eye injury will limit
effectiveness.
Saw- The saw is used by first establishing contact on what you want to cut,
and then sawing back and forth at a variable pace. The saw can be used
in extremely tight confines such as a shelter. Use can largely be done
relatively close to the body, without extending the arms forward, elbows
down to the side, this means that the saw can be effectively used even
when movement is limited by injury or clothing. Because of the proximity of
work to the body, and being in constant contact with cutting media, use is
still possible with an eye injury. Because of control and contact, precision
cuts are possible with the saw even in the hands of a weaker, less trained
person.
With the use of any tool, there is also a chance of injury. Again the
mechanism of use of the tool defines the type of injury. Using the machete
or axe involves a substantial risk of missing, or skipping/bouncing off
the media. Since the tool is essentially being swung back at your body,
there is a substantial risk of injury. This can result in devastating injuries
from impact injuries, to penetrating injures, to a combination of both.
The wedge design of the blades will split tissue and bone, presenting a
unique, and hard to treat wound. It is also possible to cause traumatic
amputation to the weak hand which is commonly used to hold/stabilize
media.
The saw, because of size, control during use, and constant contact with the
media, severely diminishes the chance of injury. An injury that does occur
will be a ripping one, no wider than the spine of the saw. These types of
wounds, are familiar, and seldom life threatening.
All three tools have their place, that said, when it comes to ease of carry,
weight, ease and safety of use. The saw wins hands down.
common examples-
tools.
effectiveness.
person.
media.
