So I got my first @Charlie Mike blade, a chisel grind in Elmax, post with pics, specs, and initial sharpening results is here:
https://bladeforums.com/threads/charlie-mike-elmax-blade.1558117/
A great knife! But wanted to discuss first observations and options for freehand sharpening a chisel grind with Elmax steel. Apologies for the longwinded post, just documenting full process i went through, and raising a few ideas for discussion.
What I did:
Learnings:
Questions for follow-up:
Pics (most are in thread, but a few here for convenience):
New knife:
Horizontal push-cut on Rizla green after sharpening on DMT C:
Close-ups of the finished edge. Not bad finish for 325 mesh and no strop.
What I did:
- Reprofiled and lowered edge angle to 30 degrees inclusive.
- I had not sharpened a chisel grind with such a high edge angle, and that plus the deep belly made it difficult for me to freehand the edge reprofile and get a clean bevel. Finally in the interest of time, I 'cheated' and used Sharpmaker and my Moldmaster 150 grit Sic stones to complete the reprofile and set a clean 30 degree bevel. Hey don't bust my chops, I'm a weekend sharpener here, I'm not
HeavyHanded
To do that, I took a tip from
HeavyHanded
, laid the blade flat on one stone with the 30 degree setting, then hold that angle, and sharpen the bevel on the other stone. That took a while but accomplished the goal of a clean 30 degree bevel. - After the edge reprofile, I went thru two sharpening progressions:
- All SiC. 150 > 240 > 600 (used Sharpmaker with Moldmasters)
- All diamonds. DMT XC (220) > DMC C (325) (freehand)
- Strop: in both sharpening progressions, I did not strop the edge. But I stropped the flat/unground side by elevating blade just barely and stropping to deburr. Tried 3 different strop options: Spyderco UF ceramic, 10 micron diamond compound on hardwood, or backhoning on DMT C or EF plates. The diamond backhoning deburred the fastest and got best sharpness.
Learnings:
- SiC can work well for EDU-quality sharpness on Elmax at HRC 61. But diamonds work noticeably better on Elmax, and get you there faster. As expected.
- I got best results with the 2-grit coarse diamond progression above. I tried using higher DMT grits, all that did was nothing or even degrade the general cutting performance. The coarse results were noticeably best.
- I tried using Spydie UF ceramic to refine: fail! It degraded the edge sharpness, even with super light strokes.
- The importance of stropping the flat side on the chisel grind. I knew this in general, but really observed here how important it was to get this step right. Elmax on this blade can get a very fine wire edge burr, hard to detect, but if you don't get rid of it, it hangs around and really impacts your sharpness.
- Anyone have tips on how to scrub/shape/profile an edge at such a high sharpening angle, without horking it, when you have a deep belly curve? Man I struggled with that.
- Stropping method I used. Should I do something different? For instance, should I strop the flat side on a higher grit diamond like the DMT EF or even EEF, that won't be so aggressive?
New knife:
