Thumb Stud Removal
I've got this 112 Slim Select that I'd like to remove the thumb studs from. They appear to be press it, not screwed on. Anyone have a solution to remove them?
Yeah, they're pressed. My 110 Slim Select's thumb studs have been loose forever. I have to keep snugging them up in a vise, but they break loose the first time I use them. You should be able to pull them off, I believe. They just cap on the end of a pin running through a hole in the blade.
After you get it off in the future if you ever wanted a stud back on it you could get a Quick Stud. Just in case
Well, my 110 SS thumbstud came off today while I was working in the yard. I lost the cap that isn't fixed to the post. Here's what your 112 will look without the thumbstud.
I'll send it in for repair with some other reblade and SPA knives.
February 2020 I had a thumb stud come loose on a 112 Slim Select that stays in my vehicle. Maybe it was hot/cold cycles from living in an un-garaged car? I kissed it with a drill to dimple, then tapped with a punch to flare a tiny bit, and reassembled with LocTite. 3.5 years later living in the car and it hasn’t worked loose again.
I should have done the LocTite bit. I was pinching it in the vise after everytime I used it but it would pop loose again in no time. On the other hand, my 112 Slim Select has been used and abused to the point where I need a reblade, but, the thumbstuds on that one have never budged.
I successfully removed the thumb stud from the orange Buck 112 Slim. I opened the blade. laid the blade flat on the top of the vice and put a thumb stud in the extreme outer edge of the jaws of the vice and tightened the thumb stud in the vice with maximum force (tighter that all get out). I then clamped a thin nosed vice grip also laid flat to the opposite thumb stud, put a piece of thin, stiff, paper between the jaws of the vice grip and the blade of the knife and leveraged the vice grip up. Just a tiny bit of wiggle and the thumb stud separated. It was then only a little tapping to remove the thumb stud shaft from the blade. No marks/blemishes on the blade and the blade is tight - no wobble up/down/sideways what so ever. I like it so much, I'm thinking of doing it to my black one.
Good deal, you got it. It'll be easier to sharpen without those studs in the way.
Next time you have a steak dinner, you can use it to cut your food and keep a toothpick handy in the little thumbstud hole. Lol.
