Exactly ! ^^^"Stronger" is a bit of a misnomer, because eventually everything will fail if you abuse it hard enough. Also, most lock systems are robust enough to allow a knife to do what it's designed to do. If you intend to do non-knife-designed-for things with your knife, I'd recommend one of the larger Cold Steels, or just get a fixed blade.
TI folders have the same major weakness as all other folding knives do, regardless of lock type: the pivot pin.
People already made good comments but I'll just add my tidbit, a common misconception is that titanium is stronger than steel. Which isnt entirely correct, pound per pound its stronger, but take two rods of equal diameter of titanium and steel and the steel will be the stronger of the two. The reason people use Titanium is because its strong ENOUGH, and lighter for the same size. Disclaimer this is an extreme over generalization and a lot more goes into this all.
I'll just throw this in : there's a reason a lot of Ti handle knives have steel on steel locks.
Wear resistance. Does that mean it's stronger?
