Tip - Marking steel
I've been looking around for a quick way to write on steel. Pencil marks are hard to see and scratching blue layout fluid is a bother.
I discovered that a liquid paper correction pen that I brought home from the office works good.... quick and clean. It gives a nice bright white line about 3/32 inch wide, drys in seconds, and can be scrubbed off with water.
I'm sure other forumites have their own favorite way of marking steel. If you've found a good way, how about sharing it with us?
I use a Sharpy. I even use them to mark patterns and then cut them out with a torch or plasma cutter, and the mark doesn't burn away. If you want a permanent mark, they're great!!
"Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!"
I use soapstone (like welders use)to mark my left over pieces of steel. Used to use felt tip markers, but for some reason the writing would dissapear after a while. This haven't happened with soap stone. And soap stone is cheap.
