- Jan 3, 2017
Just ordered King whetstones, combo 1000/6000 for my Buck 110 (420HC steel). It's my first knife sharpening purchase.
Just wanting some tips for what to expect. I'm aware that it's a pretty inexpensive stone, and you get what you pay for. Just wondering what others' experience is with this stone, and what I should expect with the steel I'm working with.
What I'm looking for:'
I decided to start using my knife at work (construction), and I want to use it farely heavily, often as a replacement for disposable razorblades. I cut lots of Tyvek (the tarps used to cover the sides of houses before the siding is put on), and I use it to sharpen my construction pencils, and opening boxes, etc.
So, yeah, the knife is taking a beating.
- Is there an ideal way to sharpen the knife so as to maintain an edge longer and cause minimal damage? It's still got the facory edge (13 - 16 degrees). Is there a more ideal edge--deeper or even more shallow?
- Technique? I can't find much info out there on this particular steel with this particular stone. Does it matter if I put more pressure while pushing blade away from me or toward me, vs more pressure with back of knife going away/toward me? I see videos of people recommending both. Some Japanese knife sharpeners seem to recommending the latter, while I see lots of videos for EDC knives on different types of stones putting the pressure either the former method, or full pressure the entire way on both strokes, or in circular motions. I believe Buck's recommended method is putting the pressure on the blade as the blade is pushing into the stone vs away. But is that only important when using their recommended stones?
- Stone upkeep: even though these King stones are "cheap", I want the best bang for my few bucks. What's a good method to keep these up as long as possible? Soak 5-10 min before use? Rince when done? Use coarse sandpaper to smooth the surface? If they start to feel too flat, is there a way to get the proper coarseness back?
Lastly, it's not entirely too late for me to order different stones if someone can convince me that they're not the right tool for the job. I'd rather know before I use them and pass the point of no return. I've got at least 4 more days before they arrive.
I'm also still working on making a strop of some sort. Havn't settled on anything yet. Might end up getting some scrap leather from... somewhere, or an old leather belt from a thrift store, or use the newspaper method. I read somewhere that some chefs use newspaper for keep up their knives--apparently the black ink works as a really soft abbrasive, good for super fine upkeep/stropping?
Thanks. Oh, and I'm definitely new to sharpening. I've tried the old Buck soft Arkansas stones a couple times. But it's a really old stone that my father in law has had for decades and I have no idea if it's still in proper condition or has beed damaged or over-used.
