Maybe I was thinking about bolt cutters.Oh, so you meant stab when you wrote cut. OK
Single hand? If it's a comparable length to a katana, I'd expect it to be heavy, relatively speaking, because a katana is typically wielded with two hands.There were medieval curved blades as well and again, single hand swords of overall length comparable to the overall length of katana, weighing pretty much the same ball park. Maybe a little heavier but not "much more" or a pound's difference. You initially touted katana in your initial post and have needed to clarify just what you initially wrote.
I clearly need to read more cultural references if I'm comparing a sword to a knife:thumbup:.You now write of a "tanto tip". Of course katana had points and they are called kissaki.
Cheers
GC
Pfft, or make a titanium battle-ax and give it to clover:thumbup:!Get 'im, Horseclover! Or send in the battle-ax guy to handle your light work!
Sounds like it would be the case in theory. I know beta titanium can roughly attain the same hardness range as steel, but I'm not too sure what the toughness is like(compared to say, 1060) at the same hardness and physical dimensions. But I would think you get the benefit of the exaggerated convex grind without as much weight behind it(may or may not be a good thing).Mostly just been a metal shop hermit lately, pale and Golem-like, skittering away from direct sunlight and warily avoiding all but the most generic of sword terminology. However, I did manage to crawl out to the woods and use one to clear a bunch of brush and wimpy saplings, and split a pile of of kindling. The titanium alloy sharpens well on a belt, or on a very fine whetstone, and it's not that much different than steel.
When visitors come and play with the titanium swords, they usually ask about machetes straight away. Such a machete would be almost impossible to distort.
I bought an ESEE Junglas instead of a machete, so I guess I can't use a machete as a machete:thumbup:.This^ is another reason to choose a Ti blade.
I would never use a traditional blade as a machete.
rolf
Yeah really huh?fwiw- I'd like to see an INFI machete also.
rolf
Hartsfield said to ignore modern technology would compromise the blade. I agree.
Sword experts agree that many japanese swords failed. Only a few swords were good to very good.
As I said before, I'd love a Busse katana with traditional Japanese geometry.
rolf
