- Nov 15, 2005
So I purchased a duel probe thermometer on amazon for $18 to test out my toaster. Below is how it turned out:
Test Setup:
Process:
Head to head (plate)
Head to Head (rack)
Full test insulated
Full test insulated (zoomed in to late time data)
Things I found odd:
Final Thoughts:
What do yall think? Anything stand out?
Test Setup:
- One probe laying on a piece of 3/8'' plate steel
- One probe laying on the rack
- Test were run on the "bake" setting @ 400 degrees
Process:
- Had recorded readings with timestamps from a stop watch
- Tested the oven without insulation then took it apart and installed KaoWool on top and sides before testing it again
- Head to head the plate data showed that the insulated toaster holds at a higher temperature, however, it doesn't seem to get up to that stable temp any faster.
- With the insulation the plate maintained a temperature of around 433 degrees which was about 15 degrees higher than the rack temperature of 418 degrees. And around 33 degrees higher than the 400 set point. The rack ran about 18 degrees higher than the set point in the insulated set up.
- It unfortunately took almost 1 hour in the insulated toaster to truly level out at a constant temp... which in the case of the 400 set point test landed at around 433 degrees.
Head to Head (rack)
Full test insulated
Things I found odd:
- I didn't think the plate would maintain a higher temp than the rack
- I didn't think the temp would level out 33 degrees higher than the set point!
- I didn't think the temp would continue to build for over an hour. Every little heating cycle just added some more heat to that plate.
- I thought the start-up would be much faster once insulated. And the leveling out of the "operating temp."
Final Thoughts:
- I think I'll be able to use this oven for tempering while having both probes on the plate with the knife.
- For 1084 I'm targeting 400-420 degrees and should be able to tune this oven on the fly... hopefully determine an appropriate procedure to get consistent results.
- The oven will require a long time to pre-heat.
- I may be able to accelerate this by pre-heating it to a higher temp (ie setting it at 450 to ramp up, then bring the dial down to the desired spot)
- I don't think I'll be able to leave this oven alone for a while; until I get a very good feel for how it runs during a tempering cycle.
