- Sep 11, 2014
Hello everyone, I got a tomahawk I have been working on for quite some time finally ready.
This is was my second try making a tomahawk.
First time I created from a 10mm thick stock which turned out to be unwieldy and heavy. I ended up destroying it to uncover other mistakes in order to make it right the 2nd time.
This one is made out of 6mm thick sleipner steel heat treated at 58 hrc with the temper drawn back on the shaft. The handle is made out of black canvas micarta which was then patterned to assist in griping. Copper pins and kydex sheath with a kydex loop belt. The sheath came out amazingly good with a very tight and snappy action.
This is the second handle I installed on this tomahawk because the first one was a multi piece construction that broke apart after a few throws.
The balance needs some getting used too but it throws surprisingly well.
Cheers everyone, I appreciate all the comments and opinions.
IMG_8138 by Panos Evripiotis, on Flickr
IMG_8136 by Panos Evripiotis, on Flickr
IMG_8129 by Panos Evripiotis, on Flickr
IMG_8205 by Panos Evripiotis, on Flickr
IMG_8213 by Panos Evripiotis, on Flickr
IMG_8218 by Panos Evripiotis, on Flickr
IMG_8253 by Panos Evripiotis, on Flickr
IMG_8254 by Panos Evripiotis, on Flickr
IMG_8260 by Panos Evripiotis, on Flickr
IMG_8262 by Panos Evripiotis, on Flickr
