- Sep 29, 2015
I made a post a while back asking about carburizing mild steels for a personal project. At the time I didn’t have the equipment for the project, but I recently made a big order. I’ve been become more interested i knife making and metal over the past year. so I finally use some money I put away to buy an Evenheat kiln so I can do more accurate heat treatments on my own.
Now that I really have the chance to play with metals using more accurate temperature control, I’ve been thinking over my carburization project more. I have a few questions about manganese and how it effects steel. I’m familiar with how it helps steel with hardenability. But I’ve have read that when there is too much manganese along with higher carbon contents it can make steel too brittle. I know in steels like 1095 or W2 or the white steels that manganese contents are usually a lot lower (.2-.4%). I would assume that having any more manganese would make these steels very brittle.
My original plan was to use some 1/8” 1018 as the base for this project because I have an access to a lot of it for very cheap. And I figured that if I was adding carbon to steel, and resulting in an unknown carbon continent, that the manganese in 1018 would probably help. But after receiving data sheets for the 1018 I have I noticed it says .6-.9% for the manganese. Which is a lot more manganese than even in 1075 which is .4-.7%.
Assuming after the carburizing a decent amount and forge welding, that the steel would have a carbon content of .8-1%. Would the manganese of .6-.9% would be too high and cause me to end up with steel that’s too brittle? 1018 obviously was designed around having a lower carbon content. so would raising the carbon do the opposite of what I want, turning it into an unusable steel?
Any advice is greatly appreciated.
Thanks for helping out,
Kevin
Kevin
