What steels are best sharpened with a toothy edge instead of a polished edge?
And what cutting task (or materials to be cut) are best done with a toothy edge instead of polished edge.
This thread is a branch off a discussion in the Traditional Forum that started talking about the differences between Case SS (420HC hardened at 56Rc or so), Buck 420HC (hardened at 58Rc) and Opinel's Inox (Sandvik 12C27 hardened at 58-59Rc).
David, I'm super confused by this because of my ignorance. Not sure where to start...
Let's begin with the difference you see in Buck's 420HC and Opinel's Inox. I don't notice much of a difference in them either in sharpening (neither are particularly abrasion resistent and sharpen easily on normal stones or on wet/dry and neither burr up as bad as Case SS or Vic Inox). And I don't notice much of a difference in edge retention but a) I sharpen both to a fine edge and b) am still gaining experience with Opinel's Inox. It may last longer and I'm just not seeing it yet.
I'm confused by why you find that Buck's 420HC does better with a toothy edge. Is this just because Sandvik 12C27 is so much *MORE* fine grained? My (perhaps wrong) understanding is that 420HC was a fairly fined grained steel and roughly in the same camp as 12C27 in that regard. And they're both hardened to close the same 58-59 range. Maybe the Opinel Sandvik is just a tick harder?
The more general question is which steels do best with a toothy edge and which with a polished edge. And after that, which is better for cutting what materials. But one step at a time I think.
As always, in your debt...
-Dave
I've settled into liking ~320 or so for Case's blades, precisely due their slightly lower hardness. I sort of found this indirectly, in noticing how one of my cheap Japanese-mystery-steel paring knives responded to the coarser grit, when looking for a decent sharpening solution for that one. That knife simply wouldn't retain any bite at anything much finer. I'd even noticed it was easy to over-strop it on simple green compound (on leather); even that would polish finer teeth out of it quickly. With that knife, I think it's issues were all due to a combination of low hardness and coarse grain; it seemed as if the finer 'teeth' on the edge would just crumble away, like sand, with just a little abrasion. Still tends to do this at coarser grit, but at least the bigger teeth last a bit longer before needing touching up.
Case's SS is better than that one, in terms of holding an edge with some bite. But it's still similar in it's ability to sharpen up easily (that's low abrasion resistance, as opposed to hardness), and in how it cuts at a given grit; that's why I tried the coarser grit on the Tru-Sharp, and discovered I really liked it. Buck's 420HC is a little harder (RC), so it tends to finish up at a somewhat finer scratch pattern for the same grit. To get the same 'tooth' out of it, I'd likely take a step down in grit, to ~220 or so.
Opinel's Sandvik stainless is in another league, so far as I'm concerned. Not so much difference in elemental makeup, but their manufacturing process is famous for it's purity and producing even finer grain. Combine that with higher finishing hardness (they spec 12C27Mod up to RC 59), and it makes for some very fine edges that will hold for a while. I've also noticed, for whatever reason that I haven't yet understood, it always seems to retain some 'teeth', even at higher finish (my Opi is finished to above 2000 grit).
I'm coming to the conclusion that softer and less wear-resistant steels like 420HC and similar kitchen-grade cutlery all respond better to a lower-grit, toothier finish. Attempting to polish them too high, even though great shaving edges are possible this way, always seems to degrade durability of the edge. On the other hand, better quality stainless that's taken a bit higher in hardness will take very coarse or very polished edges equally well, and hold them longer. Opinel's stainless is what convinced me of this, in spades.
David
-Dave
