i really enjoy alcohol stoves & have used many of the mass produced models including the vargo titanium line, the go bag, the white box, the big stainless from self reliance outfitters, & of course the reliable old trangia...
while compared to the little 1oz. vargo triad, the trangia may seem big & klunky, but they both have their place...
when space isn't a consideration i think the trangia is my favorite, it doesn't burn as hot as some others, but that conserves fuel & the boil times are comparable to the others... that is except for the big stainless from self reliance outfitters, maybe i had a dud, but the boil times were considerably longer than the trangia or any others, the burn was very weak...
now, the trangia is a top jet & so it needs a pot stand, for this my preference is the evernew titanium cross stand which imho provides exactly the right clearance so the flames stay blue & spread under wider pots, however since it is a top jet it also works well with narrower containers... i like to keep a leatherman ps4 in the mess kit & use the little pliers to lift the cross stand off stove when ready to snuff the flames... there was an ebayer who made what was called the mojo stand for the trangia (shown in pics), they work well only for larger diameter pots, & has too much clearance above the flames for my taste... if you have soot on your pans from an alcohol stove, in my experience it is from being too far from stove & a lot of the flame turns from hot blue to cooler orange/yellow, or it's some junk in the fuel...
i've tried the simmer ring on trangia, but there was always still a pretty significant hot spot that would burn food if not constantly stirred, even if i raised the pot up a couple inches higher from stove, so the simmer ring is basically just a snuff cap for me...
a nice thing about the trangia is the larger capacity, so you can get burn times as long as half an hour when filled... for fuel i use only everclear 95% ethanol alcohol, this can be used medicinally as well as a firestarter or party starter, burns hot & clean... it is pricey & not available everywhere however, so i guess denatured alcohol would do as my second choice in a pinch...
i prefer not to carry fuel in the stove because there always seems to be a little seepage that makes the mess kit contents kinda moist & smelling of everclear... perhaps that could be solved by getting a new o-ring for the lid, but it's not that big a deal to me...
there are other brands out there that use the same basic design as trangia, like esbit, & the titanium one from evernew, neither of which have i tried, but i do have a surplus swedish army trangia stove that works well but has different dimensions & doesn't fit the evernew cross stand...
anyhow, for windscreens i like the hinged folding aluminum panels, vargo makes a short squatty one which is good when space is a consideration, however they are so short they only work well with the low clearance vargo stoves... most of the time i use a tall windscreen (9.5 or 6 inches), & think it works best because you can use it with all kinds of stoves, & the taller panels keep the flame in close to the sides of pot heating it faster... basically, take the biggest windscreen you can carry i say... well, with one caveat i guess, i can't vouch for the durability of these generic folding windscreens, the testing & casual use is nothing like day in & day out regular duty, & if they do break not sure about the possibility of field repair, so maybe a backup windscreen option like a nice roll of aluminum flashing could be tucked away...
trangia with evernew cross stand & large generic windscreen
mojo pot stand, a really nice fit for the trangia, but not good for small diameter containers, & too much clearance above flames...
another mojo pic, from maker's ebay listing, not my pic
tall windscreen with silverfire scout
tall windscreen with canister stove
short vargo windscreen with vargo decagon stove which is a side jet stove with way to big a throw for this little windscreen especially with the larger diameter pots which in my opinion are optimal for use with side jet stoves, the vargo screen is much better paired with the top jet vargo triad stoves, these work very well with smaller diameter containers such as the canteens & nesting cups etc.
i did get rid of the self reliance outfitters alcohol stove, but by chance discovered the stove ring that comes with it is a perfect fit for the vargo triads, used with or without the included grill top & a little vargo windscreen it's a great minimalist combo, & easy to carry in the water bottle pouch kit...
i'll be testing the stove ring setup as an alternative for the bottle stove stainless90 mentions above because this is what happens to that when used as pot stand/windscreen for alcohol stove...
here's another thing, this site has plans for diy trangia stand...
http://www.survivalresources.com/Articles/Trangia_Stabilizer.html
finally, for lots more info & comparison reviews of alcohol stoves, check out hiram cook on youtube....
