Traveling with soap and brush
Gollnick
Musical Director
In his Recommendation? shaving soap and brush, Mr. unky_gumbi comments, "Then I can throw the starter kit remnants into my travel bag..." which caused me to think that maybe we should have a thread about traveling with wet-shaving gear, especailly lathering kit. Last weekend, I was at the OKCA show in Eugene, Oregon, so I took my shaving show on the road.
The big challenge is, of course, that the wet in wet shabving stands for... well... WET! Very often, when traveling, you have to get up early, shower and shave, and then pack up and head out. And that means packing up your shaving gear wet. Nobody wants to put wet stuff into a suitcase.
To make matters worse, most shaving soaps contain some combination of fats and sugars. Add water, seal it up, and you'll get mold growth before too long.
Most better shaving brushes are natural hairs and they also may have some soap residue in them and so if you put them away wet in a sealed container, you also risk mold growth.
For my brush, I have a plastic pharmacy bottle that my pharmacist literally gave me (they don't have a bar code with which to ring up the empty bottles, so he just gave me one). I shake out as much water as I can and then the brush goes right into that bottle and the lid goes right on. As long as you don't leave your brush "bottled up" like this long-term, it'll be fine. When you arrive at your next port-of-call, just remember that one of your first tasks should be to unpack your brush.
For my soap, I use a plastic food container made by Ziploc, their Small Bowl, 1 cup capacity. The size is perfect for a 3" cake of soap. This thing makes an excellent soap bowl. I'd use it at home if I didn't have a silver bowl that looks better on the sink. When it's time to pack up, I just shake out the excess water, put the lid on and pack my soap right up. The caution is the same as for the brush. Sealing the lid is only for temporary use while traveling. When you get to your destination, your second task after unpacking your brush is to unpack and open up your bowl. These little containers sell for something like five for four bucks in your grocery store.
For my razor I have a nice leather case. Shake out as much water as possible and then put the razor in the case. The razor is the third thing unpacked upon arrival.
since I got my DE I don't travel with my straight, so I just use a stick or sampler of soap, and no brush. what I would like to find is a blade case for spare blades. I've got an idea for using a decontamination kit as a super small shave kit, but I need a few pieces yet.
Another option is to shave the night before, all depends on preference, I night shave in winter because shaving and cold weather suck.
I, too, shave at night. I can take my time and don't have to hurry. Plus, if there's any irritation, it's usually gone by the morning. I take my shower, then I shave my face and head, wash off, apply witch hazel and AS, and go to bed.
I think an Arko shave stick would be a good one to take with you. Or just take a small jar of Noxzema.
You could save a half used shave stick and get a pill bottle to put it in. drill some holes in the bottom of the bottle for ventilation.
I'm thinking a Gillette Atra or Sensor with a custom short (or shortened factory) handle would be a great travel razor, since you'd only need to take 1 or 2 carts instead of having to carry DE blades with you.
I may have to get on the lookout for another old hollow Atra handle, like my '84 model. I can cut off the hollow part and make a 1/2 length Delrin handle to epoxy onto the top portion that has the cart retainer.
Or you could go collo rosso and make a short handle section from a short rifle cartridge and epoxy it onto the handle head.
The Merckur Travel Razor is a brilliant device: Dismantles and goes in a very neat leather sheath,takes up next to no room at all. Good razor for everyday use as well(Yeti sized hands may disagree)
A shaving stick can also be compact and it can lather OK without a brush,so that cuts down on bulk a lot.If you take a brush then try and get it out of your bag fast as damp and containers=stinky mold. Pity they don't do travel sized shave cream tubes like travel sized shampoo etc.
I have 3 Gillette Travel Tech razors from the 1960s. 1 looks to have been used once, the other 2 are unused. The cases that they fit in are tiny.
To travel, I take an old Gillette with a box, a tube of cream, and I have a pouch with my brush, AS/balm samples, and a small styptic. It's not the best for the brush, but it works.
I roll with a Schick injector. Best shave I've ever had. THere's a lab that sells blades for those by the 400 pack at a very economical price.
They're stroned! Stropped and honed!
Can't recall the name right now, though.
The brush isn't the key to a good shave, it's a hot hot HOT shower before the shave, wrap a towel, and get right to your shave. Cans of foam, bars of whatever, pucks of shaving soap, whatever brush or just your hands... just get your beard hot and wet and hack away with whatever razor you have handy. It'll go well.
I have been using the same prescription medication bottle idea for years, and I suggest that you break out the hand drill and drill several 1/4 inch or so holes in the body of the bottle as well as a few on the cap and the base. Just drop your brush in handle-first and then randomly drill holes around the circumference of the bottle corresponding with where the bristles lay.
As to blades, if I had made reservations at a particular hotel, I usually try to mail a few of my favorite Derby's ahead so that they are waiting for me when I arrive, since the TSA doesn't allow them in your carry-on luggage. Also, I would suggest that you try at least one package of whatever double-edged blades you might find at your local Walgreens, Wal-Mart or other pharmacy, so that if you are stuck without your favorites, you at least have an idea what might suffice for a few days use on short notice.
i keep my brush and a shave stick in a PVC tube during travel, and a Gillette tech and mag of Personna blades in an Altoids tin. i'm sure i could mill enough soap in the tin for a week's worth of shaves, but i haven't tried it yet.
I guess that I should have explained my travel kit for shaving:o, like Gollnick I have a larger pill bottle that I put my brush in, I use proraso soap so it has its own sealed container, I am still using my fusion razor:( right now and it has its own little case. I put all of this into a Rubbermaid container along with my toothbrush case and my toothpaste. Most of my travel is either camping, hiking, or airline travel to visit family. I prefer to shave in the evening or early morning, but I brush my teeth after meals and before going to bed. This means that the first thing I am looking for in my pack or luggage is my grooming kit, and since I am in it I take the shaving gear out right away. I never sits wet, sealed and heated for more then a few of hours.:thumbup: Shaving in the evening when camping or hiking allows my shaving kit to air out over night and gives me more time to sit back and enjoy my coffee and nature in the morning.
Its just my way of doing things and it works for me. When I order my DE razor next week I may have to change things up a bit, but not much.
BTW I have glued a mirror to the inside bottom of the Rubbermaid dish and protect it with a layer of closed-cell packing foam. It also takes up just enough space to hold everything in place when the lid is on and an elastic is stretched over the container
here's my travel kit:
i shave at night after my shower, and by the next morning my brush is dry enough to not worry about it. it's also my everyday brush, so it comes right back out as soon as i'm back home.
I roll with my straight and I learned about mold growth nastiness the hard way. Left my soap and brush in my bag in Belize (hot) and two days later when I got back from our mini-backpacking trip I had to throw my soap out. Nowadays, I pat as much water as possible off the top. I realize that I lose soap that way, but it does a good job of preserving the whole.
If portability is truly important, leave the brush at home and take some travel sized canned goo. Or use oil. Or as I do, just use some Doc Bronners (without a brush), and a Bic disposable. Truth be told, that simple low brow stuff works great. Well enough for every day use if you're not into the indulgence of the shaving experience. Certainly good enough for traveling.
Some shaving sticks can lather up satisfactorily without a brush. Personally, I feel the lather fetish is exactly that. Lubricity is more important than fine bubbles.
If you gotta have aftershave, then you'll have to make accommodations. Kind of old school and simple is the small alum block, which travels well indeed.
The Merkur Portable , and vintage Gillette travel DEs are nice, if you must have a metal DE, as they are small, and can break down into tiny packages. Feather made a portable, but it wasn't much more compact than any old DE. Then again, most DEs seem to break down quite compactly, if necessary. The inexpensive and good Lord DEs have aluminum handles which can be easily cropped like an old Gillette if desired. The Merkur Bakelite DE is really nice if you need to go ultra light (as is the Bic or just about any disposable).
I've never done air travel with a DE. I don't really want the hassle of procuring blades for my razor, and I usually prefer to not check luggage.
OR, you could try a synthetic brush, which dry much faster than natural brushes, and cream instead of soap.
on the other hand, if you're getting mold on SOAP...
as for blades, i spent a week in Toronto recently, carry-on only, and took my DE with me. no problem going up, but lost the blades on the way back.
i think it's worth a try to put a few in your carryon WITH the rest of your shaving stuff. whatever you think of the TSA, i doubt they'll ever do more than confiscate them if it's clear that you really use them for shaving. if they do take them, they're easy to find, especially if you're traveling internationally, and you can mail home what you don't use.
I was just wondering about that, if they consider it a weapon since it's an extremely sharp object...
If found in carry-on baggage, a straight razor would be considered a weapon and would be confiscated.
I definitely don't think you are gonna be aloud to bring a straight on the plane. My friend even had a problem bringing his Merkur HD in his carry-on. He had to take it apart and show the TSA guy that there was no blade in it. You would probably have less trouble with a regular BIC or Mach 3 type since they are more common, many people dont even know what a safety razor is!
I have a travel tube for my brush. I think I got it at Em's Place. I like the shave stick soap from DR Harris. Very convenient for travel. :thumbup:
Jordan
