- Jun 25, 2001
?? intesting it's at the top of 16 on my browzer
here it is by Kevin
here it is by Kevin
Originally posted by Kevin R. Cashen
Kevin R. Cashen
Basic Member
I don't want to start a stink but I would like to share some knowledge that I have came across and has proved true in all of my experience.
The phenomenon of patterning that survives heating has been mentioned and this was confusing to me also, until I accessed information that was probably gathered in a lab under what I would call "controlled" conditions. I must admit that I am a control freak and detest unknowns and rampant variables.
In steel that has carbide forming elements, repeatedly heating in lower temperature ranges (below Acm) will cause the carbides to segregate out into sheets or networks which will become very visible and have a "wootzy" or patterned appearence. You can even press all kinds of designs into this and it will take the impression in the patterning, very well. It is the concept behind the Wadsworth-Sherby technique for making "Wootz" that was considered before Pendray nailed it. Wadsworth and Sherby were two very scientific guys working in labs that knew what was going on in there and how to get it to happen.
This can be done with many steels and is easier with hypereutectoid (above .84%C) O1 and 52100 work good, I have heard that some "S" series respond very well to it also. I have even seen some folks who have dishonestly passed it off as wootz on unsuspecting people and this is why I wanted to point it out.
I did this one day just playing around with an old 52100 bearing race to prove a point. I heated it up and got things into solution and then lowered the temp below Acm and kept it there long enough for the carbides to segregate. I then dented my initials into the surface and forged it flat. The results was a very patterned piece of steel with a big "KC" showing right in the internal structure of the piece. I even heat treated it while keeping the images intact. I posted it over on Sword Forum and let people guess what the heck it was. It would have stayed there as long as I stayed in a temperature range that didn't mess with the carbides. But I could have erased it entirely, simply by heating in excess of Acm and holding it there long enough to pull it all back into solution. It is also worth mentioning that the same thing can be done with real wootz, heat it hot enough and long enough and you will erase the pattern made my those undisolved carbides.
