Trying to identify a Kelty(?) pack from the late 80's
Hello, everyone,
Once upon a time as a young college student I worked for five summers as a forestry research assistant. We spent LONG days in the field in rugged terrain, and carried our gear in backpacks that were suited very well for the purpose. I have since looked several times trying to figure out what packs these were, but do not remember them having any kind of model designation on them, although I am 90% sure they were made by Kelty.
The main body of these packs was just a cylindrical tube open at the top, with a lighter sleeve above the top that could be used to extend the capacity of the pack. At the top of this sleeve was a drawcord that was used to close the top off. The top flap consisted of a large zippered pocket that flapped down over the top of the pack, and was held down by two (I think, possibly just one) nylon straps with side-release buckles. The whole pack was made from a heavy Cordura, probably 1000-weight, and came in either blue or red. The last ones I saw might have been gray. The straps, trim, and back were all black. There was no frame, although the back was lightly padded. There were two padded shoulder straps, and I believe a simple waist belt system that was just 1-1/2" or 2" webbing with a side-release buckle- no padding. There were no external pockets, but there were several plastic lash points on the top pocket and maybe the bottom or body of the pack.
That's it, just the body, top pocket, and straps basically, but the great thing about these packs was that even if you took a hard tumble, which we often did, there was no way you were going to lose anything out of it. These were not huge packs, maybe 1800-2000 c.i. at the most. They were similar to the current Kelty Moraine, only smaller and with no frame stays.
Does this ring a bell with any of you? I would love to find one of these packs on the used market, but I don't even know for sure what I am looking for. These would have been available new in the late 80s, possibly up through the early 90's. I have not been able to find a Kelty catalog from that era, either. And, they may have been made by someone other than Kelty.
If someone could provide me with pictures or information, or any possible leads, based on the sketchy information I have provided, I certainly would appreciate it!
Safe travels!
Regan
The Kelty Redwing? They used to be made from a heavier material that may have been Cordura. Sometime (late 1980s?) they switched to a thinner lighter material. I loved the old ones, the new ones less.
Camp Trails was a good brand back then too, and used Cordura nylon in many daypacks and frame packs. Might be another option if the old Kelty can't be found.
The mother of all frame packs was the Camp Trails Omega, if you need something closer to 6,000 cubic inches. :D
Kelty had some cylindrical style packs called the Mockingbird some years ago with a closure and flap like you described but I think those all had a large external pocket on each side. I don't remember if the pockets were optional or removable.
You might want to check out Kletterwerks Rock Pack as they have a similar style. Kletterwerks is by Dana Gleason, of Dana Designs and Mystery Ranch fame.
Thanks for the help, folks!
The pack I am thinking of does not have a frame. I have (and like) a couple of the Redwings, but the pack I am searching for definitely is not a Redwing. I found a picture of one very similar on the Images section of Google:
Someone told me that this is a very basic design known as a "Klettersack", and made by many pack makers. I did not know that before!
Brisket, I will take a look at your suggestion as well. I have one Dana Design pack (believe it is called the "Loadmaster" or some such thing?); it is a weight carrying beast!
Thanks again!
Regan
Here's the Chouinard version from the early 80's.
It's my lifetime favorite pack!
Jeff
You dont have to hide the fact that you are on more than one forum asking the same questions, alot of us are:D. nbd bro, glad you got what you needed.
Anyway, thanks for pulling this info I find the klettersack design very aesthetically pleasing but I am trying to find one that wont run me almost $400 (tom binh guide pack). Ill be looking up that Dana Gleason lead, good luck to you.
Thanks again!
Regan
I have a 1980s Camp Trails daypack very similar to that. Cordura-type material called, "Armatech Cloth." Drawstring closure, small top pocket, basic shoulder straps with no sternum strap, and an unpadded waist strap. Unfortunately there's no model name anywhere on the pack.
It's probably not the name you're looking for anyway, since the Camp Trails does have side pockets.
Haha! No, not hiding at all:D. I don't get on many forums, and this one and BushcraftUSA are the only two where I thought I might find someone who recognizes older packs. Turns out, someone did on both places! I did go find the source of the picture of the Lowe pack myself though, rather than link it directly to the one posted on Bushcraft, because I didn't want to stir up any controversy. I know there are a lot of folks here that post over there too, and I think these two forums compliment each other well, but some folks can be pretty territorial.
Best of luck to you as well!
Regan
This is what I find in a search for "Kelty Mockingbird Pack":
Kelty came out with an "internal frame" backpack in 1973, called the Tour. It has a divided bag, with a sleeping bag section in the lower part. You could put skis in a sleeve formed between the side pockets and the pack. I got one to field test for them, because I was friends with Jim Lawrence. It has aluminum stiffeners to add rigidity. If it was not the first internal frame backpack, it was a very early one.
more information on the Kelty Tour is here: http://patentpending.blogs.com/patent_pending_blog/backpacking_trips/
