Yeah , this is not a BS review with file photos ................ No Sir !
Came today ..
And since I was playing with my Kizer Domin Mini ..........................
It gets to be the first knife to be bitten by a HRC tester File !
Now the way the files work is
A) If the file is softer than the blade steel , it will skate harmlessly off the steel .
This means the blade steel is harder than the file .
B) If the file bites the steel , it means the file is harder or as hard ( Near as ) as the steel . Just depends on the strength of the bite .. The harder the bite , the harder the file or the softer the steel ..
This is very much ball park testing ...
As the files go : 65 - 60 - 55 - 50 - 45 - 40 in HRC hardness ..
This should cover most knives out there and you should be able to determine which file is harder than the blade steel . There by establishing a ball park hardness for your blade steel .
So which file bit the Kizer ? It was the 55 HRC file .
I will make a list of disappointing knives ... For testing purposes !
