afishhunter
- Oct 21, 2014
OK, I've had zero luck cleaning a newly acquired (BTI) Old Timer 858OTB Stockman using the "Traditional" "Tried and True" soapy water, worn-out toothbrush and working the blades while submerged and while rinsing.
I know (or at least think I know) there is crud in the joints, since a shot of RemOil lowers the pull until it is worn away or evaporates, or whatever the heck RemOil does.
I can get a (new) sonic cleaner for around $30.
Any reason not to use a sonic cleaner to clean a knife?
Covers are "Saw Cut" Bone. (Most likely bovine bone) Liners are brass. Bolsters are nickel silver/white brass.
I'm not sure if the pins are brass or nickel silver. Blades are 9CR18MoV, (or whatever the heck the Chinese "equivalent" (note quotes) of 440C is.)
Also, my (BTI) Uncle Henry 885UH is a bit stiff to open on two of the blades. Covers are "Stagalon", blades are the Chinese "equivalent" of 440A (7CR15MoV?) Bolsters are again nickel silver and the liners are brass.
The description says I can use the sonic cleaner to clean 4 of my 6 eyes (bifocals), so it will be used for more than cleaning knives … if knives can be cleaned in it, anyway.
Thank you in advance.
