Dear all,
I have four blades avaialable from my EDC line:
1. ''Omega''
- Steel: N690 stainless steel, heat treated by me with liquid nitrogen to 63 Hrc.
- Dimmensions: OAL 150 mm, 23mm, 4,5 mm. Blade 65 mm.
- Weight: 88 gram, 152 gram with the sheath.
- Scales: Spell strike resin
- Tapered tang with a matching paracord bead.
- Grind: hollow grind
- Finish: 400 satin
- Sharpening angle: 19 degrees
- Sheath: Leather sheath for horisontal belt carry
2. SOLD OUT!
Dimensions:
OAL: 150 mm, blade lenght 60 mm, stock thickness 4.5 mm
Weight: 114 g, 197 g. with the sheath
Steel: N690 - 63 Hrc with cryo
Handle material: composite and stabilized wood hybrid
Sheath: Leather with clip for vertical carry
Blade finish: Stonewash
3. SOLD OUT!
Dimensions:
Metric: OAL 155 mm, blade 70 mm, stock thickness 4,5mm
Imperial: OAL 6.1’’, blade 2.7’’, stock thickness 1.7’’
Weight: 99 gram, 152 with the sheath
Steel: Boehler N690 stainless, cryogenically heat treated – 63 HRC
Handle: Spell strike resin
Blade: Hollow grind, hand sharpened to a 19 degree razor edge. Stonewash finish.
Sheath: leather with pocket clip
4. SOLD OUT!
Dimmensions:
Metric: OAL 170 mm, blade 80 mm, stock thickness 4,5mm
Imperial: OAL 6.7’’, blade 3.1’’, stock thickness 1.7’’
Weight: 94 gram, 143 with the sheath
Steel: Boehler N690 stainless, heat treated with liquid nitrogen – 63 HRC
Handle: stabilized wood
Blade: Hollow grind, with a 19 degree razor edge
Sheath: Leather
Price for each one is: SOLD - this includes shipping with tracking and Pay Pal fees
You can contact me at: rusevknives@gmail.com, also my Pay Pal address
Please check https://unboundknives.com/ for more cool stuff!
Thanks,
Nick
1. ''Omega''
- Finish: 400 satin
2. SOLD OUT!
Dimensions:
3. SOLD OUT!
Dimensions:
4. SOLD OUT!
Dimmensions:
Sheath: Leather
Thanks,
Nick
