Uncle Henry UH?
I’ve got an Uncle Henry 3 bade pocket knife that I’m having a problem identifying.
It looks like 3 blade Schrade + Uncle Henry USA 897UH or 885UH “Stockman”, but the blade tang clearly shows Schrade + USA 833UH which is for the Double Blade “Prairie Jack"! I’m a bit confused and can use some help.
Is the actual blade with the stamp the same blade as the other stamps and they simply put it on a different model?
The same blade (longest) that all other stamps I’ve seen is where this stamp is located. I’ll try to post a picture link showing the knife and closeup of the stamp. Thanks.
I’ve tried using a Flicker account image link, but it isn’t working. Should I use another service?
Flickr: Open the photo in Flickr. Note the four icons at the bottom right: edit, share, download, and a shopping cart. Click on download and select "View all sizes." Right click the photo and select "Copy image address." Come back here and select the "Insert image (Ctrl+P)" icon at the top of the message. Insert the address that you copied.
Yep. "End Of Days" knives are fact, not fiction.
I was able to use the desktop version of IMGUR to upload the image link. I think the problem was trying to use the mobile app which is limited. Attaching the image.
It's possible that it was an end of days knife but it might also have been part of a batch put together with leftover blades and sold at the factory store (or elsewhere) as seconds. What you have there should be an 834UH (Rancher). It used the same clip blade as the 833UH. The 833UH was discontinued in 1995 but the Rancher stayed in production right up to the end in 2004.
Eric
I appreciate all the information shared here. This is a pretty neat knife, thanks for sharing it with us GH.
Is there any catalog of known end of days or seconds variations of schrade?
