Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I don't like D2. Hard to sharpen without diamond sticks and an abundance of time. Hard to heat treat properly, Chips, breaks, lacks toughness, and overrated unsuitable blade steel in my opinion. Especially if the blade is over 3 inches in length. Which further reduces toughness. And I can't afford Dozier customs in order for the steel to be done right. Chinese D2 is not even true USA D2 according to ANSI specs.I'm a little surprised to see steels like AUS-8, 8Cr13Mov, or the slightly more refined 8Cr14Mov here. They are common enough to be in a lot of pockets under $50. Having a good knife and love for that knife in one of those steels might tip the scales. Still, I have to wonder if those folks just haven't put the same time in with better budget steels.
Chinese D2 might have better edge retention but when the humidity creeps up over 90% in the summer and sweat becomes a fact of life, its low corrosion resistance becomes an issue for me. I've occasionally gotten spots on 8Cr13Mov or AUS-8 in the summer but not like I do with D2. Another issue with Chinese D2 is that while the edge retention is much better than 8Cr13Mov, it isn't as good as is should be. For instance, the following steels shouldn't be competitive with it on edge retention but they often are. That said, these are my favorites:
14C28N is hard to beat as an all-rounder. It shows up here and there under $50. It's better than AUS-8 or 8Cr13Mov in pretty much every category.
9Cr18Mov is a great choice under $50. It has excellent resistance to corrosion. The edge retention is good and rises to great with the heat treatment it sees in the Civivi and Sencut knives from WE. Those knives are my first recommendation to anyone looking for something good under $50. Those are knives that persist in my EDC rotation despite the presence of knives costing several times as much.
This post finally triggered me to ask this question - I have seen, in regards to the low-end, Chinese "?cr??mov" steels, them referred to as 8cr18mov, 8cr13mov, and now, 8cr14mov. Is that a different steel, or were other people just mixing up the alphabet-soup of a name? Apologies for my ignorance, thank you for any info!I am tied between 8CR14MOV and 12C27. And they usually run anywhere from $15 to $35.
