Hi! First post!
I was searching for some reviews on the Hapstone RS system, and I came across a comment critisizing it. He said the following in a comment:
On YouTube, you can find some sharpeners using alternative kinematics. They don't have a central pivot and are based on a linear bearings instead. They are much better. With this schema, the cutting edge angles do not depend on the thickness of the abrasive stone or plate. Moreover, when the amount of removed metal is considerable, it also doesn't change the angles.
He also posted several videos of different sharpening systems , but I don't understand the difference between them and the hapstone.
One of the several he shared is this one
So if someone can provide me with a explanation (a pic I think would be enough) I would be very grateful!
Thanks
Thanks
