chiral.grolim
Universal Kydex Sheath Extension
- Dec 2, 2008
Universal Kydex Extension 2.0
A few years ago I developed the "Universal Kydex Extension" as an accessory to lower the carry-height of knife sheaths on the hip so that the handle is not above the waist and poking users in the ribs or impeding the belt of a back-pack. Such accessories are common but I've not found one quite as versatile as this.
The Universal Kydex Extension 2.0 is designed to mount to virtually ANY kydex or plastic sheath with holes spaced either 3/4" o.c. or 1.5" o.c. - this includes sheaths that come with various models from TOPS, Becker, Kabar, ESEE, Ontario, Survive!, Gerber, Boker, Buck, Bradford, Azwelke, Mashed Cat, Buy Brown, 710 Custom Design, and so on. The extension works on knife-models as small as the Survive! NeckerII or as large as the Busse FBM and beyond. No matter your knife model, if you have a sheath that you think might be able to accommodate this extension, you may find it well worth your while to try it out.
Here are a number of knife models with different sheaths ALL OF WHICH are compatible with the Universal Kydex Extension 2.0.
My original design was made from two layers of 0.080 kydex held together with eyelets in the 'head' and 'base'. While very strong, the design was challenging to reproduce with a high level of consistency in quality. I have since revised the design into a single-layer 0.125 kydex platform that presents sufficient strength, stiffness, and also flexibility but now features a higher level of consistent quality in manufacture.
The extension is designed to be mounted through holes along the edge-side of your sheath. If your sheath features holes spaced 3/4" o.c., these will match up with the corner-hole in the base of the extension and the angled holes below. The angled arrangement of the holes in the base allows the user to customize their carry-angle such that the knife rides straight-vertical, canted 45', horizontal, and a plethora of angles in between.
Each extension comes with specific mounting hardware - a long screw + pillar and rubber spacer for the top hole, and another set for the lower holes at the angle of your choosing - simply tighten the the sheath against the lower rubber washer to secure your angle.
The off-set "L" shape keeps the arm thin for easier carry and places it behind the handle of your knife when mounted vertically. The holes in the base of the extension allow the user to mount their sheath vertically, horizontally, or at a variety of angles. You can angle the knife for cross-draw, comfortably scout-carry below the waste-strap of your back-pack while keeping the knife mounted to your person rather than your pack... The angle-adjustment also accommodates oddly-angled or swerving handle-shapes like the Busse Muk.
