Kerry W
- Jul 2, 2012
What would you suggest as a superior alternative to D2? Since this is my first attempt to design an axe I welcome the experts opinions on this forum. Thanks.It is odd, indeed. Curious as well.
Thanks for your reply Steve. I have read MANY of your posts and have high regard for your opinion. In its current iteration it is pretty much a wedge. I got some inspiration from a photo of a Tuatahi Racing axe I had by my desk for years. Per your suggestion I think I will add some mass to the poll and see what it looks like. I can (in the software) calculate the center of gravity, evaluate and adjust accordingly. I was just going for what I thought was nice lines.
Looks way thicker in the eye than is needed. Especially in the front. The bevels remind me of the original Kelly Perfect. The sharp step of the bevels just in front of the eye was rumored to be a weakness and the reason more examples didn't survive.Hello. I have been interested in making an axe in a somewhat non traditional way as well. Mine, if I actually do it, will be 3D machined out of a solid billet of D2. The images are of the model I have came up with so far. This is my seventh iteration. It has some features of axes I have admired aesthetically. I would welcome others opinions and feedback. View attachment 987186 View attachment 987187 View attachment 987185
It is a bit thick in the eye. A con session I feel like I need to make for machinability. The small inside fillet is .125”. So, a 1/4” diameter end mill. I may try to move the bevels out a bit or soften them a little. Ultimately I doubt this small axe will see hard use, but I would still like to evolve a good design. Thanks for the feedback.Looks way thicker in the eye than is needed. Especially in the front. The bevels remind me of the original Kelly Perfect. The sharp step of the bevels just in front of the eye was rumored to be a weakness and the reason more examples didn't survive.
S7 and D2 were my final choices for the steel. Ultimately I have decided to go with D2 for the better edge retention. I feel the robustness of the edge has a great deal to do with its geometry and heat treat. I plan to harden it to around 55-58. If the edge breaks I will try again. Maybe out of S7! Life is full of experiments. Thanks again for your input.What 42 said. I am not an expert but D2 is known to be on the brittle side, indeed.
S7, if you want to be fancy (but don't expect incredible edge retention). Otherwise, go with the "tried an true" carbon steels (1065, 1075 and even higher in carbon if you are willing to temper them lower).
Thanks. I don’t have a copy of that catalog, but I will be looking for it. I did find an image on the internet. Is this close to your suggestion?I agree with what Steve said. For the bevels, I would look at the Lippingcott patterns on pages 7-9 of "The American Axe and Tool Co.", 1894 catalog. I also like the Southern Kentucky Pattern Bevels on page 25. A high centerline would also be important to me. I do like your initial design as a starting point.
Figure 13 and Figure 15 from "An Ax To Grind":Another pattern, which is my favorite all around design, is figure 13, page 7, in "An Ax To Grind"manual. Also, look at the top photo in figure 15, page 8, a Bluegrass Western pattern double-bit with bevels and a high center.
...On some axes like Tuatahi are ground flat with a slight high center line...
Yes, this. Even 1060 would do. Easier to work with and still gets adequately hard. 1075 or 1080 would be ideal.
Man, if it ain't too late to change your mind, I think you're making a mistake.
There is no way D2 will have better "edge retention" vs. S7 in the context of a chopping/impact tool. If you're making a knife that will slice dirty carpet all day, then yeah, the added wear resistance of D2 will win the day. But you give up a huge amount of impact resistance with those big carbides. They won't have a chance to do their job if the microscopic edge is breaking away from impact forces.
I have several chopping tools that have never once gotten dull from abrasive wear. I have to sharpen out nicks and dings and other impact damage before they lose their bite from wear.
Now, I do have a few hatchets that I've managed to only use on clear clean wood (i.e., wood carving projects), that had lost their hair shaving edge by the end of the evening, but were still working fine. And you know what? It only takes 2 or 3 swipes per side on a fine hone to restore that hair shaving edge, in a matter of seconds. That's the potential improvement you'd see from D2. Saving literally 6 seconds of sharpening every few hours of use. But the potential downside is huge. Take a look through this forum at all the pics of old axes guys have found with toes, heels, or big chunks of the bit broken completely off. And that's with steel that is, what, like 2 or 3 times more impact resistant than D2?
