I'll let other folks experiment with that. Even using a diamond blade on a tile saw you'd have a hard time cutting sintered silicon carbide.
I'd bet a very thin kerf diamond blade would zip right through. A wide kerf, on the other hand...
Quick update on my experience so far with my 2x4 plate. Out of the box I was impressed with its cutting speed. It was definitely cutting rather than burnishing which is a problem I have with some AlOx sintered ceramics. However the edge finish it was leaving was pretty coarse, like a 1k finish, not the near mirror I was hoping for based on some pictures that were posted here. I ordered some 1 micron diamond powder to refinish the surface, but the lapping process revealed that the plate was not flat. I went down to some coarser abrasives, but after little success and further examination I discovered the plate was warped and/or bowed. I'm still trying to work with it, but the plate is very hard to grind. So I'm not giving up, and I can't draw any conclusions about this plates potential performance until I can get it flat, but for $80 I'm a little frustrated and disappointed.
It's specifically noted in the item description that if extreme flatness is needed that lapping is required. All sintered ceramics that aren't surface-machined post firing will have a certain amount of warp to them. This degree of irregularity is smaller than that of most bonded abrasives after a handful of strokes have been made on them, and so doesn't have a meaningful impact on the sharpening performance for most cutting tools.
You should be getting a high polish off of it, and it may be possible that you're scraping the bevel on the edges of the stone, which may leave a more coarse finish due to the mechanical nature of how sintered ceramics perform. If that's difficult for you to achieve, soften the edges of the stone a bit with a fine diamond plate.
No worries. Flattening does take time, but it's ultimately not too bad. Just use coarse diamond lapidary grit to start and take it from there. I lapped a considerably larger plate of a sample material that had a pretty severe "groove" distortion in it and it did take several hours of grinding, but you should be able to lap smaller plates with more typical surface distortions in only an hour or two. Then bring it up to your desired surface texture using either loose grit for a more matte finish that's more aggressive-cutting or use a diamond plate for a smoother, glassier surface. Extreme flatness is only needed for finishing precision edges like straight razors and the like. Otherwise, the degree of variation caused by a freehand stroke is already introducing inconsistencies in the angle with which the blade and stone interface, and like I said, the degree to which the plates are out of flat in as-fired condition is equal to or less than the degree to which most stones (especially soft ones like water stones) will be after very little use. Machining to dead flat would increase the cost by a decent amount (consider the price jump from a Spyderco fine to an ultrafine--they're the same material, but the latter is machined) and the base material itself is quite costly, so with that in mind it made the most sense to offer it with the surfaces in the as-fired state and if people needed greater precision they could supply their own labor, greatly increasing the accessibility of the stone, since that degree of flatness isn't needed for most applications. My personal user plates are totally stock, not lapped, and I use them for touching up all of my knives without issue.
