- Oct 17, 2007
I built my first heat treating oven a little over 13 years ago, and at the time I purchased just about the cheapest and most basic PID/temp controller from Auber Instruments. I think it was about $45 or so, and it was basically just a set it and forget controller. If I recall, I might have replaced it one time over the years when it failed to turn on, but for the most part it was a pretty bullet proof little controller. That said, it didn't really have any extra features, like ramp/soak settings, although I didn't really need that at the time. If I did, I just manually changed settings on the fly, and did what I had to do.
Well, I finally got tired of manually punching buttons up and down to change temps and decided to see what's new in the last 13 years or so. I found the Novus n24k48 and after reading the specs, decided to give it a try. They typically run around $100 to $120 or so, and they have an app called "quicktune" that you can download to a computer, a phone or a tablet. It also has bluetooth connection for uploading your program, or you can also just manually set and select programs, though it's about 100x faster on the app.
Untitled by AR Custom Knives (Andrew Riley), on Flickr
First impressions, this thing is surprisingly smaller than any other PID I've used. The face/opening size is standard, so I didn't have to modify anything there. Wiring seems to be pretty standard as well. It has up to 5VDC pulse for SSRs, so I was able to eliminate a separate power supply I previously had to use, and it also has up to a 3V relay for things like alarm settings and what not. You can also expand the base unit with other modules as needed if you want to add wifi, modbus or other alarms and such. Since I'm still after a relatively basic setup, I didn't need anything extra and it was a simple swap out with my old one.
As for the programming and the app, it's pretty basic and straightforward, and dare I say, unimpressive (but functional). There's a little bit of a learning curve, but it's really not too bad.
It'd be nice if you could name programs rather than just "program 1, 2, 3, etc...", but it's not a big deal to have a list next to the oven that says what steel each program is setup for once you've set them up.
So all said, it's not a TAP controller by any means, but for $100, it's a pretty big bang for the buck in my opinion, and about 1/6th the price of something like a touch screen controller. All in all, I think it's an option worth considering if you want ramp/soak programmability in a very small package that's relatively easy to set up, and if you already have an oven with a standard sized PID, it's about a 5 minute swap out.
Anyone else using one?
Untitled by AR Custom Knives (Andrew Riley), on FlickrFirst impressions, this thing is surprisingly smaller than any other PID I've used. The face/opening size is standard, so I didn't have to modify anything there. Wiring seems to be pretty standard as well. It has up to 5VDC pulse for SSRs, so I was able to eliminate a separate power supply I previously had to use, and it also has up to a 3V relay for things like alarm settings and what not. You can also expand the base unit with other modules as needed if you want to add wifi, modbus or other alarms and such. Since I'm still after a relatively basic setup, I didn't need anything extra and it was a simple swap out with my old one.
