USAMS PB9 power bank features a minimalist body design with a large capacity of 10000mAh. It is equipped with 2 USB ports so that it can charge two devices simultaneously. It measures just 93.5 × 64.2 × 23.5mm and weights only 190g, making it very portable.
Product Features:
● Compressed size and volume, more lightweight and portable.
● 10000mAh big capacity, provides sufficient power.
● Digital display screen, shows the accurate percentage of power.
● Dual USB ports support two devices charging at the same time, fast and efficient.
● Upgrade intelligent chip, automatically adjust the current output, both ports support 2A fast charging.
● High quality Li-polymer battery cell, safe to use.
● Multiple protection: over-charge, over-voltage, over-current, temperature, anti-reverse, short circuit, over-discharge, over-power, under-voltage.
● ABS fireproof material, anti-wear and scratch.
● Meets boarding standards and can be taken directly to the aircraft.
Thanks to its small size and light weight, this mini power bank is much more practical than ordinary power bank. It doesn't increase the burden when you go out and is convenient to put in your bag or pocket, doesn't take up space. It is available in black and white, the price is only $13.99: https://gearvita.com/usams-pb9-digital-power-bank.html
Recommended products:
sabbat x12 pro
xiaomi amazfit gtr
Product Features:
sabbat x12 pro
xiaomi amazfit gtr
