- Mar 10, 2020
The workshop I normally use [live in an apartment, nowhere to run sander] has an Edge Belt and Spindle Sander instead of a normal vertical/horizontal belt sander I see being used. It has this model that uses 4"x32" belts. I plan on doing most of my bevel grinding with a jig and well likely be doing the blade profiling on this machine too. Same goes for most of the handle shaping. For finishing, I'll be doing everything by hand using micromesh pads.
Do you think using the edge belt sort of like a vertical belt sander is feasible?
