- Feb 3, 2020
Hi All - I got my new grinder yesterday and need to build up an extension cord as I will be mostly grinding outdoors. I am trying to make sure I use the correct wire size in the cord. If I check the wire size calculators I am coming up with needing a 12 gage wire based on the specs on the face plate of the motor and the run I am dealing with +/-42'. I will be running it at 230 volts
I have a couple questions:
1 - I have gathered that there is an amperage increase on the incoming side of the VFD but I am having trouble figuring out how much. Does anyone have a rule of thumb or calculation I can run to determine how much increase in amps I should plan for? The VFD is a KBAC 27d.
2 - If I run the VFD at 2x to get more RPM out of the motor does that further increase the draw?
If there is anything else I should consider in my wire sizing please let me know. The motor faceplate is shown below. Thank you in advance!
