redsparrow
- Oct 3, 2014
Yes, seems he's cut a lot of rope with several different blades.
The blades of Victorinox knives are hardened to around 56 Rc, which they have deemed appropriate for everyday tasks while remaining easy to sharpen. Yes, this is softer than many modern knives.
For my part I like them this way. One of the jobs I had during college was cutting steaks for a popular restaurant, and the preferred knife for this task was a 10” Forschner (Victorinox) butcher knife. Its handiest feature was that a minute or two on a corundum stone at the beginning of a shift and a few touch ups on a steel would get you through a couple hundred pounds of sirloin roasts.
Since those days I’ve valued ease of sharpening over edge-holding (within reason). There is no place in my life for “supersteels.”
With that said, I can understand why others might want a knife they can use for weeks or months without sharpening.
Ain’t diversity great?
I also use the 'shaving arm hair' method also to check when I've arrived at sharpness. Unlike trying to find some receipts lying around to test on, my arm is always there.I use shaving sharp to decide when to stop sharpening. If it won't shave arm hair, I keep at it. Once it shaves, I'm done unless I'm trying for tree-topping or hair-whittling sharp for some reason. Sometimes it's fun to do. Mostly it's not. Even freehand on a coarse stone, shaving sharp isn't at all difficult.
This is huge. Thick-ground edges and thick spines are a real pet peeve of mine. Traditionals are usually better than moderns in that department, and although certain mass producers do appear to put warranty costs above cutting performance, V'nox doesn't. I like that.
I don't take mine to the stone very often. Once I get a useable edge, I touch them up on a strop . . . OFTEN! Yes, they do dull quickly, but the strop usually does the job and keeps me from taking too much steel off.
And the Trekker / German Army Knife serrations take better to stropping than stones and sticks.
Zieg
Since reading your similar advice posted many moons ago, I've been trying your advice not only on my stainless pocket and fixed blade knives but also on the big kitchen slicer my wife loves to abuse. That sharpening works dandy and the edge holds up much better. Thank you.The secret is don't polish the edges. I've used a corse edge from a silica stone or corse diamond hone and the edges last a lot longer. I haven't used a shaving edge for a long time now, as I fond for most field use, a real toothy edge works better on all kinds of cordage, fishing line, cloth, and food stuff. SAK steel works best toothy.
Just make sure you don't sharpen too many at once or you'll be out of test material as it were
I'd use the cat...
It is an obsession, and kind of a silly one at that for a day to day utilitarian pocket knife. That adge you get off an India stone or diamond home is very similar to the edge you will get off the bottom of a coffee mug, smooth stone out of a creek, or the old fashioned "carborundum" stone like we had in the Boy Scouts. A good all purpose working edge.
Since very few of us are barbers, and the odds of having to shave with our knife is slim to none, a shaving edge is kind of silly, unless the whole act of sharpening in itself is your hobby. I've tried all kinds of mediums for the sharpening of knife blades, and found that a very good working edge is an easy thing to do with crude materials. IKEA soup bowls have a great ring on the bottom for meat carving edges, and any piece of broken flower pot will put an edge on that will slice right through jute twine and plastic blister packages.
Then time I had to actually really use a knife a real life or death emergency, it was a toothy edge on the sheepdog blade of a well used Buck 301 stockman. It cut a seat belt in an upside down old Datsun B210 that was boring. The rough course edge sawed right through the nylon webbing just fine.
Don't obsess. Life is too short.
Check out this old post. LINK > > >Is it just me and my sharpening, or does Victorinox blades dull rather quickly?
Yep, when it comes to Jacknife this is always sound advice!So true and well said. Do it like this guy.
Here you go.I'll try to find that Vid and post it later.
