This is always a tough choice. Since the beginning, I always chose the Phillips scewdriver over the corkscrew. I did not know that the small flat head screwdriver that is combined with the can opener is intentionally made to fit a Phillips head screw too. It fits a #2 Phillips head screw perfectly. Because it comes out of the end instead of the back, I always use it instead of the Phillips screwdriver. Also, if you get the corkscrew, you have a place to keep the little eyeglasses screwdriver that lives in it. You can order the eyeglasses scewdriver as an accessory if your model did not come with it. So, the corkscrew may be a better deal for many.
Also, the slot in the end of some of the Phillips head screwdrivers is to unzip a sardine can.
Also, the Vic. saws cut like crazy. I won a bet by cutting through a 2x4 in 30 seconds.
Any comments or questions?
