The Victorinox Farmer is a 93mm Alox (anodized alumimum alloy) handled SAK (Swiss Army Knife) - it is one of the "Pioneer" series.
The Farmer is basically the Pioneer with woodsaw -
or compared to the Soldier - has the addition of the woodsaw, keyring - and has the regular scalloped shield Swiss Cross logo. Also on the other side there is a plain panel area for engraving.
[note: the Victorinox Soldier is the actual knife issued to the Swiss military]
The 93mm Farmer is one layer/backspring thicker than the 93mm 2 layered Soldier due to the addition of the woodsaw, so that layer/backspring is slimmer than normal.
The Soldier is just slimmer than a regular 91mm 2 layered Red Cellidor handled SAK, because of the thinner Alox scales, and no corkscrew.
The main blade layer/backspring on both the Farmer and Soldier are thicker than the regular 91mm SAK.
The main blade of the Farmer is the same as the Soldier, but it is usually not year stamped as on the Soldier. These 93mm Alox models have slightly longer, and noticably thicker blades than the regular 91mm SAKs.
The more substantial backspring on these 93mm Alox SAKs also mean that there is a little more effort required for closing the main blades - which can be seen as mostly a good safety thing - if the tougher opening does not present any problems.
The woodsaw of the Farmer looks like the same as on the regular 91mm SAKs -
There is a slight difference between the large screwdriver/bottle opener/ wire-stripper tool on these 93mm Alox models compared to the regular 91mm SAKs - but it's only just noticable - the whole tool and specifically the screwdriver blade is just a bit wider - but for me there isn't any practical difference to speak of.
The Can Openers look like the same standard tool as on the regular 91mm SAKs
(note: the small screwdriver tips on the can opener are designed also to fit #1 and #2 Phillips screws)
To me the Soldier feels just right in terms of weight, heft and thickness for an Alox model.
So the Farmer feels just a little thick - but the woodsaw is a very worthwhile addition for outdoor use.
Vincent
http://UnknownVincent.cjb.net/
http://UnknownVT.cjb.net/
Vincent
