Victorinox florist knife.
Several months ago, I picked up one of these at a gun show here in Texas. The guy had a whole table of knives and a wide selection of slightly used Victorinox stuff. These included what was TSA confiscated knives with a ton of the smaller SAK's like the 58mm's, assorted classics, ramblers, mini champs. Out of curiosity I picked up the florist knife because of the minimalist design that had a smattering of old time flavor. Single blade sheep foot with rugged construction.
Well, I've used and lightly abused it over the spring, summer and fall. It's been gardening, fishing, camping, traveling, and used on the work bench in the shop. So far, its taken all I could dish out and comes up grinning. The sheep foot has been a great all around pocket knife blade, that makes short work of stuff from summer sausage to fishing line, to thorny stuff growing over the fence out back. It can be opened with work gives on, and the chisel ground blade has been a joy to cut with. Bluntly, it cuts like the dickens.
I've been on the hunt for another pocket knife that cuts like an Opinel, ever since I got burned out on Opinels by their messing with a good design because of some lawyer. The Victoriox florist knife cuts like an Opinel, without the water swelling issue or the possible failure of structure from one of the wood fingers that the whole blade/bolster/lock assembly is mounted on. The Victorinox is all pinned in nylon scales with real metal liners that are not affected by moisture or any lateral stress on the joint while cutting. The spring gives great walk and talk, very snappy, but smooth steady action. Blade pull is about like a Victorinox pioneer, or other alox handled SAK. With the nylon scales, the whole knife is light weight enough to go in a shirt pocket with no noticeable presence. Did I mention that it cuts like he dickens?
All the years that I carried a Buck 301 stockman, the sheep foot blade ws always my go to blade that I used. It was just such a handy shape to use for a wide variety of stuff. When I had to crawl into an upside down old Datsun that was burning and had to cut a seat belt, it was the sheep foot blade that got used. One fact that may have had some influence was I had a hysterical obese woman hanging upside down and thrashing around wildly and I was afraid to have something pointy out. The sheep foot blade worked fine as seat belt cutter.
The nylon handle is all curved edges. Theres no hot spots or corners that stick in the hand. Each end is rounded off, and the long edges of the handle are very soft radiuses that no matter how you hold this knife, theres nothing to bug you in cutting, heavy or not. Nothing to create any pocket wear.
I remember the old knives on the steam boat Arabia, that were recovered, and how many of them were sheep foot blades. After several months now of using this florist knife, I now understand why this pattern of pocket knife was so popular in the "Old days."
I very highly recommend this knife for a low cost but rugged pocket slicer, that you won't cry rivers over of it gets lost. Easy to replace and great cutting performance and rugged construction are highlights of this pocket knife.
Oh, did I mention that it cuts like the dickens?
Lot to admire in that pattern Carl:) Tough yet it's appealing and very much work focused. Also it goes well in the hand and what's the use of a pocket-knife however beautiful or intriguing if it doesn't feel good in the hand? Not much....;) Nor is it going to weigh down the pocket a pet hate of mine.
I had one of these which was very kindly given to me by a female forumite, but I lost the knife within a month and like one other knife (this one costly) became permanently lost over the years. Embarassed about it as it was a kind gift. But it worked well:thumbsup:
Regards, Will
This knife is pretty good,but i wish blade was little longer,still find Opinel garden knife better,yes,the wood swells but its easy to open on this one,and 12c27 blade cuts like crazy and holds the edge.Victorinox should make single blade thin longer blade,find their steel pretty good for any task,my alpineer sak with blade and corkscreew is one of my favourites,outcuts all of my spydercos,benchmades and most other knives,still functions like first day,quality is flawless for 20$ only.
I have one and like it overall, though I am not a fan of the chisel grind. The blade shape and size are great though!
J jackknife
Does that SAK Florist cut as well as a Recruit and/or Farmer and/or Tinker/Super Tinker and/or Huntsman?
I think it cuts better. The blade is ground to a very thin chisel grind. I stress very thin, like an Opinel behind the edge. Slices like a freshly sharpened Opinel. Kind of like having a strait razor in the pocket.
If they made florist with longer blade,id get few of them,nice little knife,opinel should make models with plastic or micarta or g10 handles,and leave blades as they are.The plastic versions that they have,have thicker blades with some almost useless gadgets....opinel in g10 and maybe with basic spring without lock and with lockback too would be awesome knife.
The Gardner is a great knife, I had one as a teenager and it was my go-to utilitarian blade.
I'm not so big on the chisel grind these days so I've been meaning to pick up a day packer but just haven't gotten around to it yet.
Thanks for the update on your experiences with the Vic Florist, Carl. :thumbsup::thumbsup::cool: Does yours have a key ring attachment? I've seen what seems to be the same model both with and without ring.
Anytime you write that a knife "cuts like the dickens", I take notice, because you sure were right when you used to say that about Opinels! ;):thumbsup::thumbsup:
If anyone reading this thread wants to see a related earlier thread, here is a link:
https://www.bladeforums.com/threads/sheepfoot-experiment.1652647/
In the earlier thread, I mentioned that I'd been seriously thinking about buying one of these, and that Carl's glowing review sealed the deal for me. But being the Potentate of Procrastinators, I still haven't picked one up. :rolleyes: But with birthday and Christmas coming up, it's the time of year I usually put together a knife order, and a Vic Florist should be included (along with maybe a canoe or two, a sowbelly stockman, a Pioneer X, a toothpick, Rough Rider carbon model, ...)! :D
- GT
I reckon the same could be said of any of the smaller SAKs. ;)
-- Mark
Oh yeah, the smaller SAK's are very good pocket knives. More rugged than you would think for the small light weight objects they are. But even so, it took my wife to show me just how much I had under estimated the little classic that I came to know and love.
- GT
Thanks for the kind words, GT. This was an update, and I should have noted that in the thread tittle.
No, the one Have does not have a keyring attachment, and its the one thing I wish it did. I would have liked robe able to attach a lanyard to it, but as I'm not in Maryland on on small boats a lottos the time, its not areal biggie. Somehow I made it to 25 years of carry with. my old Buck stockman without losing it, so I'll just keep that bandana wadded up on top of it in the pocket. In the shirt pocket of the Magellan fishing shirts that are my warm weather shirt for most the year down here in Texas, the right pocket has a zipper on it. Nothing getting lost from there.
And yeah, the thing does indeed cut like the dickens! :D
I have used one of these for about 5 years now, I think they are great little knives for a lot of applications. My 11 year old granddaughter grew a liking to it so I had to order a purple one for a Christmas gift.
Thanks for the additional input, Carl. :):thumbsup::cool:
- GT
There was one in the GAW Box, it had a clip point blade.
I was tempted to keep it as it had great F&F and the blade was so 'snappy'. Very satisfying to open and close.
In the end, I figured I wouldn't carry a knife that had a short blade in comparison to the length of handle you'd have to carry around.
I used to spend a lot of time with an old Rastafarian/botanist on St Croix who ran an eco hiking business taking tourists on walking tours through the rainforest. All he carried was a Vic florist knife and a 12" machete. He said that was all he needed. Amazing what he did with just those two blades.--KV
Jackknife is absolutely correct, these knives are very thin behind the edge; thinner in fact than any of the 84 or 93 mm SAK’s I own. Between the thinness of the edge and the snappy spring they are a pleasure to use.
