I've been thinking of trying stock removal with pre-laminated VToku2 san mai, the stuff that's clad with soft stainless and nickel sheet in-between that and the carbon core to stop carbon migration. The recommendations from the two places I've seen it are that Bill Burke says soak at 1350F for 30 minutes then raise to 1500F and soak no more than 10 minutes then quench in oil. It has about 1% carbon, 0.4% chromium, and 0 to 0.5% manganese so it makes sense to soak a little at 1500F, but is the 1350F soak something to do with the san mai or is there an advantage soaking longer below austenitizing temp?
Also, anybody seen a chart with suggested tempering temps for desired hardness? Or suggestions from experience?
This is probably over my equipment's capabilities since I currently use a two brick forge for HT, but I thought it might be fun to make something for myself. I might be able to swing using a kiln at work but not sure how deep it is and whether it can accommodate the knife I want to try making.
