kronckew said:
we used to soak our wooden ramrods in kerosene for a few months, kept 'em nice & flexible.
What did they use before kerosene, whale oil?
Most likely since it was widely available for lamps and such.
The ndns often needed a bow at inopportune times for cutting wood.
The trick was too debark the wood and keep it rubbed down with animal grease until it dried. We also fire seasoned and hardened wood but that's real tricky and if you don't know what you're doing the extreme heat of the fire will create the same kind of cracks as if you didn't keep it oiled or greased up.
It's easier to do once a great deal of the moisture has left the wood.
I've made Ash Pipe stems from freshly cut branches and saplings and have had small heat induced cracks form from drying and seasoning them with a propane torch.
In this case they didn't hurt anything as the wood would never be flexed and weren't deep enough too keep the stem from sucking air when smoking the Pipe.
I fire hardened an Ash bow I made when I was about 14 that was cut at the wrong time of the year. I roughed out the bow that had somewhat of a natural recurve and then reinforced the recurve by forcing it around some big heavy nails in the side of my Uncle Bud's abandoned outhouse made from native lumber.
I was lucky it didn't crack under the hot Oklahoma sun and still don't know why it didn't unless it was because I had reduced its size substanially and then put it under pressure.
It was dry too the touch when I hung it up.
After hanging for a couple of weeks I took it down and started finishing it but it wasn't quite ready.
I oiled it down and rehung it for another couple of weeks.
When I next took it down from around the nails it was a little loose hanging in them and held its shape.
I started finishing it again, carved the nocks in the ends for the string and started tillering it.
When I got it about down too where I wanted it I built a fire and started fire hardening it. You could see the oil and the sap that was left boiling out of it. I kept oiling it and putting it over the fire until I had it like I wanted it.
The fire hardened Ash had a beautiful finish on it. I don't know how accurate it was but with a set of bathroom scales and a buddy and after several slip ups we drew it too full draw and it registered 65 pounds.
I had that bow for a long time. We didn't have room in the trailerhouse we lived in for it so I kept it undernath the trailer.
Some bastard stole it.:grumpy:
