Welder basics
What is a good recommendation for a beginner welder? I don't know anything about welders, types, 120 or 220? I'm looking to do some basic stuff, fixtures, etc.
Sent from my SM-G900V using Tapatalk
A good recommendation, is to take a class on Welding. There are Adult night schools, and local community colleges that can get you access to the class you may need.
MIG or GMAW is probably the easiest to start with.
I read a couple of welding forums too
By far the most recommended one is
https://www.millerwelds.com/equipment/welders/mig-gmaw/r1021572-no-name
It will run 110 and 220
Take some time at the Miller website, read the specs
There are books in the resources section.
The videos by wall mountain are good and available free at your local libary
http://www.weldingvideos.com/orderonline.html
GMAW (MIG) Wire Feed DVD
Flux Core Arc Welding DVD
http://www.weldingtipsandtricks.com/
I would say that MIG is the easiest to learn, but taking a welding class would be very beneficial!
I will say that taking a class at a local community college is the best advice. Then you don't teach yourself bad habits. I have students everyday that wanted to buy "X" welder prior to taking a class, but after taking it they decided that they liked a different process more (usually TIG), and they are thankful they spent the semester in my class.
Kevin , thanks for your efforts . A basic course or two will shorten the learning curve . Even basic machines have some very nice features these days .Use a 220 if you can.
Thank you gentlemen, I may not have time for a class right now, but I can probably get some lessons from some folks at work before I rush into anything. I'm in the process of adding some power to the shop, and 220 will be added.
If your looking for a good compromise between cost, versatility, and ease of learning you can't go wrong with a basic wire feed unit. Innerflux a.k.a. flux core- it'll do almost any thickness you'll need in a home shop, isn't too bad of a price, and is quite easy to learn.
Mig is probably next in line for all the same reasons as innerflux wirefeed, but you have to juggle one more thing- gas pressure. As a plus, it opens up possibilities in aluminum and stainless.
That being said, if you have the money for a tig setup, get it! It's the corvette of welding- you'll love it if you can justify/ swallow the price tag. They are so clean and nice, but a slightly longer learning curve to it.
Stick is probably the cheapest to get into, but is one of the more challenging to learn, probably about the same as gas welding. Gas for your thinner stuff, stick for the thicker stuff. With gas, you can cut with the change of a torch head.
There isn't one best answer, but a balance of compromises depending on what you want it to do, how much the budget can afford, and how much time you're willing to spend learning.
I'd go with a Miller max star 200. It takes 110 or 220 but it'll trip the 110 breaker at higher amps. It does stick and dc high frequency start tig. I got a mig too but barely use it. Tig gives you the greatest control and you can do fusion welding without rod. Stick is good for Rusty dirty and painted stuff especially with 6010. 7018 is the easiest you can just drag it.
You can't weld rust dirt or paint.
There's no downside to clean metal.
You burn right through it. If you like grinding go for it. Sometimes it don't need to be pretty.
It ain't the pretty,it's the quality of the weld ! Rust hold's lots of moisture not good for aproper weld !
I think you are talking about the little inverter (suitcase) welder, Miller makes a couple of them, and you are right it's a great little unit, but for the price you could by a decent crackerbox welder and a little flux core unit and probably have some change.
For the price of one of those new you could probably by a Miller 225 or 250 used and have a unit capable of stick, tig and mig and have a generator too.
Dang I googled it didn't know they cost that much. I bought mine for 300 bucks lol.
^^^^This
For sure.
I fell in love in one of those classes
With a TIG welder. We have been together now for thirty years or so. She isn't cheep but OOOOHH LA LA !
If you want:
Portability and to weld dirty, rusty, ferrous metal- stick(SMAW)
Speed and easy to learn- MIG(GMAW)
Weld just about every metal known to man- TIG(GTAW)
