I see by your profile you are an old knifemaker, but don't know how new you are to damascus.
It takes a good size heating chamber to weld. A small chamber won't do it well (or at all in many cases). The billet needs to be completely at weld heat before setting the weld. Many makers have a forge just for welding (and contamination by some elements ,like copper, can poison the atmosphere for welding purposes). A blown vertical forge is preferred by many.
Heat to around 1800 and apply borax/flux. Reheat , reflux. Heat to near welding heat, scrape and reflux. Bring to full welding heat where there are no dark stripes showing between layers. Make sure it soaks long enough for the center to be as hot as the sides. Take out and GENTLY set the weld with a 3# hammer. You are not forging out the billet here, just fusing the metal. Many bad welds come from too much hammer force. Reflux and reheat after setting the weld. Re-weld, repeat, turn it on the sides and set the welds from the side. If anything starts to open up or show a line, go back and reflux/re-weld until the billet is a solid piece of steel. ONLY when it is solid can you draw it out or hammer hard.Before drawing out you should forge the billet into a neat ,clean, straight sided bar of steel. If you cut corners and get sloppy, it will go in all directions. You can tell by the sound when the billet is welded up solid. The full welding heat is only needed to set the weld, drawing heats should be in the normal forging ranges. If you keep the billet above black heat at all times, you can fold and re-weld without grinding. The big tricks are fluxing, scraping and brushing away scale and excess flux, and keeping the billet at heat.
Stacy
