BJE
Basic Member
- Apr 12, 2006
Picked up a sharp pebble 400/1000 off the net pretty cheap to try a water stone, I’m a good freehand sharpener with over a decade getting great results using nearly any oil stone, diamond, or ceramic, even coffee mugs and window edges, but so far I am hating this water stone.
It doesn’t cut as aggressively as I expected, maybe about the same as an India stone, but that’s not why I am frustrated.
I can get a burr after a lot of strokes, so I know I’m apexing and as stated I’m experienced with bench stones and freehanding, however after refining the burr the edge feels rounded over, no burr either side but edge isn’t crisp and doesn’t slice well. My technique is the same as I use for oil stones and diamond stones, wrist angle lock and everything except wetter lol.
Tried with a slurry, with minimal slurry, light pressure, and heavier pressure, just can’t get a finished edge on this thing. Tried different knives, same result, after this last attempt on an opinel paring knife and being dissatisfied with the final edge, I broke out an old Norton crystolon stone that’s far from flat and needed some attention, however a few mins with it and I’m left with a nice crisp edge with some tooth. Not even going finer than that Norton and I can get a better edge than the 400 or 1000 grit side of this water stone.
It harder for me to feel where the edge is contacting the stone with the water stone, the feedback is different than I’m used to and hard to discern if I’m riding the shoulder or flat on the bevel. However it’s also hard to feel that on diamond stones and I have no problems at all with those.
Is this stone just crap and not a representative of water stones, or do I really have to start my skills from scratch to learn these? I didn’t think it would be that different than using any other flat abrasive stone to sharpen with.
I have only had one other stone that acts similarly in results and feedback and it’s an arctic fox, just can’t ever get a good final edge with that thing even though I want so badly to like it. It also feels a bit frangible in use like the water stone, but doesn’t really shed much, yet the SiC Norton also breaks grit loose and no problems using that. Even still I can get a better edge off the fox than this sharp pebble.
Seems to me that I’m running the edge into the slurry and it’s dulling/rounding the apex while sharpening, yet many thousands or millions have used these types of stones and get results.
So do you more water stone experienced folks have any advice? Is it just that different a learning curve from other benchstones and I need to keep at it, or is this stone the cause of my frustration and should be ditched before I swear off water stones forever?
I tried edge leading and following strokes until I go to the final passes to minimize burrs, then edge leading with light pressure, I have also tried edge trailing in a stropping motion for final strokes and neither gave satisfactory results. I know it must just be me, as a rock is a rock and will work, but I can’t figure out why it would be any different technique wise than what I have been doing for years.
I have walked away from it for several days to reset after my first attempt so as not to get discouraged, sometimes have bad days like that, but this wasn’t my ne of them as I went straight to my old beat up stone and using exact same technique got a great edge off it in a fraction of the time. What gives?
