Wenger Ranger
Sep
I was looking for a NKP-friendly folder that's long enough to do some food processing at the office. I prefer it to lock for added safety. Basically it's going to serve as a kitchen paring knife, albeit a foldable one so I can pocket it and put it out of sight. Since the task is not demanding, I looked for an economical model.
The moment I saw the Wenger Ranger 51, I knew I got it. The knife has slender, conservative look made even less threatening by the swiss shield. The blade is 3.9" and full flat ground. It locks, and as a bonus it's one-hand open. All this for under $30.
At this low price I pulled the trigger and bought it right away (it's in transit). Any one of you has experience with Wenger Ranger? Until know I only got experience with Vic 111mm models. They shouldn't be too different, should they?
I have a Wenger Ranger 51 with pocket clip that I received as a bonus in a trade with a member of this forum - very generous of him. It's a nice knife. The push button lock release is pretty slick. The scales are a bit bulkier than those on my Victorinox One-hand Sentinel PE with pocket clip. I also greatly prefer the clip design on the Victorinox One-hand Sentinel. Either knife should work equally well for food prep. Let us know what you think about it when it arrives.
Edit: Almost forgot... Another difference is that the Ranger 51 lacks the toothpick and tweezer.
Here's a photo of my Ranger 51:
Thanks for the picture. It looks kinda thick, but I guess it's ok because I'm only gonna carry it between my office and the pantry.
Thanks for the picture. It looks kinda thick...
No problem. Here's a quick (and ugly - sorry for the rainbow effect in the scan) comparison shot of the Ranger 51 and the One-hand Trekker. The Ranger is thickest at the middle and tapers off on the ends. In the middle, the Ranger is actually thicker than the One-hand Trekker. You can also see that the clip sticks out quite far.
...I guess it's ok because I'm only gonna carry it between my office and the pantry.
I don't know, man... how far is your office from the pantry? (j/k) :p On the plus side, the 4" blade is roughly 1/2" longer than the blade on the One-hand Sentinel. You might find the additional blade length useful in the kitchen.
I should mention... Not all of the Wenger knives have thick scales. Here's an older SwissBuck that's quite thin:
Holy moly it is thick! That's a belt knife for sure, not a pocket knife. The 3-layer version must feel like a brick. I'm glad that I'm getting the one without pocket clip.
The scales seem to be mostly hollow so it's not very heavy but it does take up some space in a pocket. I also received a sheath in the trade but I'm pretty sure that the sheath was originally a separate purchase. I ended up removing the pocket clip since I felt that it got in the way of a comfortable grip.
I got the Ranger 51 today.
- Knife is rather bulky, this is definitely one of the thickest folders I have.
- Relatively light weight for the size because the plastic scales are hollow.
- Steel liners on both sides and an additional aluminum liner behind the locking side. This makes the knife more rigid but not as light as it could otherwise be.
- The blade is held closed and open by a back spring, but in the open position it's secured by a liner lock.
- The unique liner lock extends all the way to the handle spine, where it's actuated by the Wenger logo button.
- Ergonomically speaking, it's very good. It fills my medium hand nicely.
- The full flat ground blade is about 0.8" thick and tapers to the tip. This should make it an excellent slicer.
- The thin blade profile and relatively soft steel makes it really quick to sharpen. I don't like the rather crude factory edge, so I worked on it with my DMT setup and it didn't take long at all.
- Blade length is 3 3/4", but the cutting edge is just 3 1/4". Rather wasteful. Spyderco Endura at identical blade length has 3 1/2" cutting edge.
- There is noticeable up and down blade play. Not too bad, but can be annoying to people used to solid lockups.
- Blade is brush-finished and appear a bit crude.
Edit: I'm revising this review because now I'm convinced that I got a used knife instead of factory brand new.
- The Wenger logo/button is scratched up. There's no way it left the factory in that shape. People could be sloppy, but they have to be downright blind to let this through.
- The edge was sharp but rough, consistent with field sharpening.
- The dents on the spine.
- The rust spots.
- What I thought as rough edges around the thumb hole are actually pitting caused by rust. I remember because my LM has the exact same thing around its thumb hole, but after several years' worth of use.
Want one with:
Pocket Clip
One-hand opening, locking blade (PE/Serrated- no matter)
Corkscrew
Toothpick & tweezers
Rest of the blades (bottle/can opener, etc. immaterial)
Anybody know of one? I'll buy it Now.
Want one with:
Pocket Clip
Corkscrew
The only pocket clip models from Vic and Wenger are single bladed ones. None has cork screw.
I have a 78 from the older Ranger line which had been a display model and I bought for cheap. Its pretty handy for food prep and such, since it's long enough that you don't get the handle and other tools dirty. I think you really made a good choice with getting the 51 though. I wish I had done the same.
I suggest the Vic Alpiner, 110mm, locking blade, corkscrew, tweezers, toothpick. It is thin, and lacks only the clip. I prefer the blade shape on this series than the OHT for kitchen work.
