- Jul 10, 2002
I was making a pouch sheath for a knife, i cut the leather to the form i wanted, glued in the shaped welt, made my stiching indents with a home made pointy wheel thing on the top of the welt, drilles small holes thru the welt and bottom side of the sheath, folded over the top part, turned it upside down and drilled the holes thru the pre-drilled holes, so now the holes go all the way thru, stitched it up, looked pretty (good for me
), and was pretty tight, decided i wanted to try the wet forming to show the outline of the gurd and handle and make it fit just right. I took the sheath ran water all over it and inside it and put it in a zip lock bag with a little bit of water in the bottom ( a couple table spoons), and let it sit over night. wrapped the whole knife in saran wrap and inserted it into the sheath and started rupping around where i wanted the form. got to looking pretty good but the leather would show moisture when i would press on it (too much water i guess) and wasnt drying very quickly, so i put it between 2 pieces of padding stuff and put some weight on it thinking that would help with the formingand left it over night. the next night i took it out and took the knife out, it still seemed just a little damp, so i put just the sheath into a toaster oven and set it for 200 degrees, i figured that should dry it out and not husrt anything, and left it there for 3 hours. after the 3 hours were up i took it out and it felt dry and harder than when i put it in. now comes my problem, when i tried to insert the knife it seems the leather has shrunk about 1/8" or so and doesnt fit anymore. So i guess my questions are what order do i do things if i want to wet form a sheath, and if i put a sheath and knife wrapped in saran wrap in the oven will the saran wrap melt or anything or will it still make the sheath too tight, or do i have to air dry it?
edit: i did not seal it yet with bees wax or anything, i was going to save that for the last step.
