- Mar 22, 2006
Just wanted some opinions from the experienced guys ont the quality and functional differences between the 2 if any, they both seem comparably priced
Just my 2 cents worth. I think that the Wetterlings is a much nicer looking and working hatchet than the Fiskars however in a survival situation I would opt for the Fiskars as it is almost indestructible. We deliberately tried to break one here at the school during a course two years ago. We even drove over it (the handle) about a dozen times and when we put a big ass flat rock under it we managed to crack the handle but it was still fully functional. I don't know of any Hickory handle that would stand up to that kind of abuse.
Oldman/Marty Simon
Misanthropist has it correct in my opinion. For the "average guy" who does little chopping, the Fiskars hatchet will be just fine...providing he spends some time reprofiling. The Fiskars hatchet or axe, as it comes from the manufacture, is actually better at splitting wood, than chopping it. The well-made, sharp Wetterlings, is heads and tails beyond anything Fiskars produces for chopping. No comparison.![]()
The only thing that troubles me about the synthetic handels are everything has a limit, after that it will break, even though the wood handle might need some work from tie to time, I wold still want to be able to rehandle my axe, after a fiskars handle breaks, It cannot be rehandled.
That is true - everything has a limit. But for some things, the limit is so high you cannot reach it at all, or if you can, not easily. This is the case with those Fiskars handles. You can break one, if you try really hard, but to accidentally break one is so difficult that it can be justly called nearly impossible. If you break one of those Fiskars handles, then it's either send it off to warranty or buy a new one. Let me put it this way: I have accidentally broken wood handles on axes, but I've never accidentally broken a Fiskars handle.
The synthetic handle certainly doesn't look very traditional, though. The wood handled axes are much prettier, and the good ones do perform better than the much cheaper Fiskars.
Well, the whole discussion was about Wetterling being the same price than fiskars. Wetterling quality may be "diverse" but if handpicked you can get very good ones.it's about two times cheaper than any wood handled axe better than it,
While this is technically true, the Fiskars actually don't break. At all.I wold still want to be able to rehandle my axe, after a fiskars handle breaks, It cannot be rehandled.
Funny I would think quite the opposite: thinner profile better for hardwoods, provided that hardwods are generally so hard you won't drive the axe to were the hollow grind shows anyway.GB is really for softwoods,hollow ground, where a wetterlings has a more straight, or flat grind.
Splitting is another story.
As for soft wood, it is easier whatever the axe you use anyway.
While generally true, not a definite truth. Axes are different from knives and hollow ground generally means brittle because it generally infers thin cross section which is brittle, but not really brittle because hollow ground.Too brittle for hardwoods, Big knives usually dont have hollow grinds for strength.
