Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
If you're lucky, you may get some M2 steel, it's good stuff, but the odds are it will be a lesser type of carbon steel. Without knowing the chemical makeup, it's really not worth the effort to work it to shape, grind it, heat treat it & then expect a good knife blade. If it's cheap, it's good practice steel, but as the above poster said, pay for good steel if you want good results!
What mill do you work at JT? Vagans or Boise?I work for a saw mill and thy NEVER use old blades let alone braze new carbide onto old blades. Once the carbide has been sharpened past it’s useful life it’s scrapped and the carbide knocked out of it. I’m not saying it doesn't happen but not at large production mills. 99% of the time the blade has started to develop cracks Along the very edge by the time the carbide is shot. I have confirmed with the manufacture that the big circle saws I have access to with carbide teeth are 8670 and the smaller ones are 1075 with a pinch of chromium.
but I will side with LCoop in that it’s generally not worth the effort if you don’t know who made it or don’t have access to a steady supply so you can have it tested. Generally big blades have to be some type of spring(ish) steel to support the load and return true.
