- Oct 15, 2021
After spending a couple of days at 22.5 degrees I decided to tape up and take another 1/2 of a degree off. I started with the extra course grit to set the angles at 22.0 degrees on each side. The S45VN on this blade again proved to be very cooperative as it took out further unevenness from the manufacturer. This S45VN is what I would call talkative in that if you are using a light enough touch you can feel and hear the vibrations of the stone on the steel maybe another way of saying this is that S45VN gives great feedback.
I could literally tell when I had reached 22 degrees and flipped a bur as the steel became more grabby on the stone so I would get off the more grabby areas and work the less grabby smooth feeling areas until they started grabbing and then finish with a whole side leveling stroke remaining mindful of the tip at all times.
After flipping and recalibrating with the digital angle cube followed the same procedure until the entire edge was grabby on both sides and then just used the weight of the stone finish up using tip to heal strokes 30 each side and touching up blending the tip, after this it was just running the remaining 4 grit progressions up to 1000 grit, On each grit progression 30 strokes each side and constant angle cube recalibration.
The recalibration might seem like a drag but after a while you get pretty fast with it and the Blitz is super easy to get fine adjustments swiftly.
The end result was nice even bevels and a sharp knife but I can tell I will not be staying at 22 degrees for long 21.5 here I come lets see how long I can resist playing with this steel.
So far I am finding S45Vn to remind me of CPM Cruwear in the ease of sharpening department but not quite that easy it just reminds me of Cruwear as a steel that seems to like to get sharp. Taking S45VN down 1/2 of a degree at a time may seem like a slow boat to China but I am maintaining excellent control and even bevels this way and it is actually more enjoyable than trying to take off a whole degree or two at a time. S45VN seems to cooperate very nicely when you do not try to hog off too much steel all at once.
