Yes but it's not something i would imagine you would ever do. It would be basically trying to blend the edge into the blade grind in reverse. Rather than doing a regrind of the knife to think it behind the cutting edge and then putting the convex on, kind of like a zero grind.Can I thin behind my convex edge by flattening it, without changing the edge angle, and without shortening (raising) the primary grind?
This is a very good pic which also reinforces what i said as well as your point also. As i said numerous times, at the very edge if you continued on a straight line the V grind will always be thicker. But, if you treat each of those left and right corners as knife edges, which one is actually realistic? One is a usable convex, and the other is basically a sharpened cube 90 degree angle for a knife edge. Now i've edited your picture to show what im talking about, and basically the only point i have been trying to make - If a normal, usable convex was put on a knife with a normal hollow grind or saber ground blade geometry (not a zero grind convex from the spine) then the convex will always contain more steel behind the edge, even tho it would be a chunky edge. I'm talking shoulder to apex being an even distance for the entire primary edge bevel. The mathematical formula has always been correct, but it hasn't been the focus of the example i have been trying to explain. Either way guys, i'ts been a good discussion, no chips on any shoulders, i enjoy this kind of thing, we're both correct, we're just making different points.
These threads always turn into geometry fights.
Well, my picture is asymmetrical. I apologize. I now realized that the unit of measurement is 4:5 which should be 1:1 (aka 5:5). This is an accident on my part, however it does not advance your theory. You are simply not understanding basic geometry.
Shoulder-to-apex is irrelevant. Your primary convex bevel will still have less behind the edge if it were convex.
And no, we are not making different points. You are totally misunderstanding geometry. I can prove so after I take a shower and allow time to draw this out.
Geometrical and mathematical proofs were my niche in college. Better buckle up!
You don't strop your razor before you shave???
I don't even have any words anymore. Just tired of terminology word twisting in order to side step a tiny point i was making. I've been in this game a stupidly long time mate, nearly 2 decades of sharpening and experience with edges, re-grinds and geometry of all sorts. I know what edge angles are in relation to the visual bevel. Just because you interpret a few words in a way that seems different to what i'm saying, you assume i've somehow confused and mixed up 2 basic principles when it comes to edge geometry. It's almost like there's a willing ignorance in the air sometimes. I'm out, thread has crumbled anyway. This forum is much easier to be a part of when you're just lurking sometimes. Good luck with everything OP.You're conflating visual bevel width with edge angle. They are absolutely not the same thing.
I appreciate what you're trying to do, but im not misunderstanding anything, i know exactly what you're saying (and i agree with the theoretical part), i'm not new to this. You are going to draw up something that has a convex much thinner than the V edge, BUT, its not going to join into the blade grind like a normal knife would, it will be a lower angle but join into the blade grind the same way that a zero grind convex would. which is NOT my point. The edit i did on your picture explains my point, but of course you can then go and thin out the convex to match the V grind which will then make the V grind have more metal. It's a back and forth game now.
Think about this, here is a real world example. A Chris Reeve Sebenza arrives at your door, they have a very thin hollow grind as it is, but it also has a convex edge bevel since that's how they come from their factory, much more convex than say spyderco or benchmade. Now, they don't always seem to cut so well, and like many people, they prefer a V edge on their Sebenza, so they put it in a guided system (wiked edge, edge pro) whatever, and apply a V edge but keep the exact same edge bevel thickness to not change the look of the edge too much. Result - the knife seems to cut through material much better. Why is this? because the V grind is now much less obtuse than the factory convex. I've seen it and done to countless knives for years and years. If the Sebenza came with a much wider bevel that allowed for a much thinner convex edge it would slice great tho, but it would be extremely thin behind the edge due to how thin the hollow grind already is and how high the convex has to go up the blade to match an equivalent V grind.
I like my own Custom knives that I make to have a Convex Grind & and Convex edge because they Ffffing Cut! And also really look bad Ass in tight Spandex Yoga pants!
Nuff!View attachment 710584 Said!! LOL!
